Quantcast axles? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > axles?
East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.Great deals on Rigid Lights. SR and E series
Old 09-13-2005, 07:43 PM   #1
79cj5Dr
axles?
ok ive put a d44 in the rear i need to upgrade the dana30 up front note i gotta stay legal here so i need the same with would love to put a dana60 but i dont think its short enough so i figure d44 i run 4.56 gears with 35's now locked solid constant front and rear now input very welcome
79cj5Dr is offline   Reply With Quote
Old 09-13-2005, 11:36 PM   #2
XJ-NoDough
Shoot, run 37s.
[SIZE=2][B][COLOR=Blue][B]My DD
'89 XJ Limited
204,XXX miles
Leather, Loaded[/B][/COLOR]
[COLOR=Red][B]4L Selec-trac[/B][/COLOR]
[COLOR=White][B]Automatic[/B][/COLOR]
[COLOR=Red][B]3"-4.5"ish Homebrew lift[/B][/COLOR]
[COLOR=White][B]16x8 MB Motoring Rockers[/B][/COLOR]
[COLOR=Red][B]265/75R16(31[SIZE="1"]ish[/SIZE]"X10.4") Goodyear Wrangler M/TRs[/B][/COLOR]
[COLOR=White][B]Trimmed w/ Bushwackers[/B][/COLOR]
[COLOR=Red][B]Stock 3:55 gears[/B][/COLOR][/B][/SIZE]
[B][COLOR=White]sans big audio[/COLOR][/B]
[B][COLOR=Red]Homebrew intake w/cone filter[/COLOR][/B]
"Some people are like a slinky... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs." :my dad
XJ-NoDough is offline   Reply With Quote
Old 09-14-2005, 12:07 AM   #3
cmotsvt
Axles can be narrowed.
cmotsvt is offline   Reply With Quote
Old 09-14-2005, 12:33 AM   #4
Sierra Drifter
Jeep Wagoneer axles from I believe 86-91 are Dana 44 drivers drop and correct width. They are set up for leaf springs so you will need to have the leaf pads removed then the LCA/UCA, track bar, and coil spring brackets welded on. RE makes a kit with all the brackets that you need, unfortunately it costs $379.
Wagoneer axles are low pinion. If you want a high pinion (stronger r&p and better drive shaft angle) then you want a Ford F250 Dana 44. Have it narrowed to same width as Wagoneer D44 and then you can run stock Wagoneer innner shafts. Chevy and Dodge Dana 44 are passenger side drop and low pinion.
The other issue is lug pattern. None of them are 5 x 4.5. with is the stock XJ pattern. You will either have to change the rear to match your new front and then buy new wheels. Or you can use wheel adapters to get the 5x4.5 pattern. Or lastly you can run Dodge hubs which in certain years had the 5 x 4.5 lugs.
If you are planning on running 15" wheels then you need to be aware that they will not clear most jeep or ford disc brake calipers. They will usually clear chevy single piston calipers.
I want to do this swap myself this winter so I've been reading up on it.
A good site for Dana 44 axle swap info is:
http://77cj.littlekeylime.com/web_rs44.html
good luck.
2001 XJ RE 5.5 ED w/T&T Y-link longarm, 37" MTR's, D44/D60, ARB's, Rubicon Tcase, and all the usual junk.
Axle swaps & build thread: http://www.jeepforum.com/forum/f11/rebuilding-front-dana-44-a-397243/
Sierra Drifter is offline   Reply With Quote
Old 09-14-2005, 12:41 AM   #5
twisted_ed
you will find that 90% of the peolple on here will respond to you like they did to me when i asked this same question:
leave the front, the way it is, just spend the money and upgrade, regear with good component and a locker, and upgrade the axleshafts and finally convert to crossover steering or hi steering if avaialbe (havent confirmed that yet.) the 30 is plenty strong in most applications so you should be ok;
but i hear you, my ultimate plan is to get myself front and rear dynatrac like rearends. i wish to build my own but i need to wait till i get a garage and welder
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
My Jeep
twisted_ed is offline   Reply With Quote
Glock Forum
