Quantcast Axle Nut Keeps Coming Loose!!!!!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Axle Nut Keeps Coming Loose!!!!!!!!
Spartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase RequiredDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 10-03-2008, 08:22 AM   #1
DEEPERTHEBETTER
My Axenut Comes Lose A Mile Exactly After Being Tightend. I Thi It May Be The Bearings Or The Hub. Any Ideas??????
DEEPERTHEBETTER is offline   Reply With Quote
Old 10-03-2008, 08:28 AM   #2
mortalenema
Drivin' me nuts...
mortalenema's Avatar
cotter pin?
'99 Classic: "Emma"
8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite
JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s
Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents
Jeeps with Teeth #1
MN Jeeper #14
_____________________________________________
"When is the best time to do things? Who is the most important one? What is the right thing to do?"
"BORN TO WHEEL" PRODUCTS FOR SALE
**********More designs here**********
mortalenema is offline   Reply With Quote
Old 10-03-2008, 09:04 AM   #3
DEEPERTHEBETTER
The Carter Pin Stops It From Coming Off But It Is Loosening Up For Another Reason Just Cant Figure It Out
Old 10-03-2008, 09:05 AM   #4
DEEPERTHEBETTER
Not The Pin It Stops It From Coming Off But Something Else Is Making It Come Loose Just Cant Figure It Out..... THANKS FOR THE HELP
Old 10-03-2008, 09:18 AM   #5
Scottmc01
1993 XJ Cherokee
Did you torque it to 175 ftlbs? Those suckers have to be tight.
93 Jeep Cherokee Country 4.0 AW4
Flowmaster / APN header
3" mismatched lift
30" Bighorns on V5's
Scottmc01 is offline   Reply With Quote
Old 10-03-2008, 10:23 AM   #6
1offroadin4x4
Really....I crank those suckers down with a breaker and put all my weight on that thing to get it as tight as possible, never had one come loose, and they come right off w/ impact.
[COLOR="Yellow"][SIZE="2"][B]03 F-250 Super Duty Diesel
01 Cherokee Sport[/B][/SIZE][/COLOR]
[B]Member Of: [COLOR="Black"][SIZE="2"]Empty Pockets Offroad Club[/SIZE][/COLOR][/B]
[SIZE="2"][B]emptypocketsoffroad.org[/B][/SIZE]
[url]http://www.youtube.com/watch?v=uORO_JCaOAY&feature=related[/url]
1offroadin4x4 is offline   Reply With Quote
Old 10-03-2008, 11:49 AM   #7
CharlieMopps
1989 XJ Cherokee
put a second nut on? There's certainly room...
CharlieMopps is offline   Reply With Quote
Old 10-03-2008, 12:26 PM   #8
tangofox007
Are you installing the nut retainer in addition to the Cotter pin?
tangofox007 is offline   Reply With Quote
Old 10-03-2008, 12:53 PM   #9
justanotherjpr
My hunch is that the retainer is either destroyed or missing.
justanotherjpr is offline   Reply With Quote
Old 10-03-2008, 07:21 PM   #10
KamekLocked
Yeah if you have the washer and axle nut torqued to 175lb/ft and the cotter pin you should have no problems.
1999 Jeep Cherokee SE l 4.0 HO l AW4 l NP231
Dana 30/Chrysler 8.25 l 31x10.5x15 Wrangler MT/R
Flowmaster Delta 40 w/stock pipes
Optima Yellow Top l Custom Headlight Harness
Alpine CDA-9886
KamekLocked is offline   Reply With Quote
Old 10-03-2008, 07:44 PM   #11
tangofox007
The Cotter pin isn't enough; the nut retainer is also required.
Old 10-03-2008, 08:08 PM   #12
KamekLocked
Oh shoot forgot to type that in, thanks for correcting that tango. To add more as long as everything is nin good shape there should be no problems...
Alpine CDA-9886
Old 10-04-2008, 06:51 AM   #13
DEEPERTHEBETTER
i actually have it tore apart right now i was told the bearings may b shot, i did torque it to 175, i do not have a retainer but it hasnt since i bought it and i have been in some deep mud and been doing some climbing, ive had it about 6 months and it just now started doing it. thanks for the help and let me know what u think about it being the bearings!!!!!!!!!
Old 10-05-2008, 06:15 PM   #14
DEEPERTHEBETTER
Finally Got It Fixed, The Hub Had Came Apart And Bent My Axle And Rotor, Got It Back Together And Made A Few Upgrades While I Was In There, Thanks For The Help
Old 10-06-2008, 10:38 AM   #15
justanotherjpr
Please put a retainer between the cotter pin and the axle nut.
Glock Forum
