ax5 strength? - JeepForum.com
post #1 of 6 Old 04-17-2004, 08:14 PM Thread Starter
slayer2000
slayer2000's Avatar
ax5 strength?
I"m looking at a 93 cherokee with a 2.5 and a five speed. This should be the ax5. The engine smokes pretty bad I'm told but I'm going to swap a 4.3 v6 or a 350tpi into it. I have a complete running blazer to swap parts from but it's a auto and I would prefer to keep the 5 speed. Will it hold up to either engine?
slayer2000 is offline
post #2 of 6 Old 04-18-2004, 12:52 AM Thread Starter
slayer2000
slayer2000's Avatar
Anybody?
post #3 of 6 Old 04-18-2004, 01:04 AM
MadDogXJ
MadDogXJ's Avatar
Originally Posted by slayer2000
Anybody?
Zzzzzzzzzzzzz......
The meaning to life is to live, So Go Live....Offroad :o)
1998 Cherokee, 2 Door, Black.
4.0 L Power Plant, NP231 Transfer Case
32" BFG All Terrain Tires on 15"x7" "Grizzy" Jeep wheels
Helix TB Spacer with K&N Replacement filter.
C4x4 Rear Bumper/Tire Carrier with hitch and towhooks :)
DPG Rock Attack XJ Gas Tank Skid Plates
RE 4.5" lift - With 1" 5/8 Spacer up front, and 1" Spacer and 3/8 shim in back. So over 6" of lift.
MadDogXJ is offline
post #4 of 6 Old 04-18-2004, 06:36 AM
cfkingfish
cfkingfish's Avatar
From looking at the Novak adapters site (http://www.novak-adapt.com/catalog/e...s_adapters.htm), they don't sell engine adapters for the AX5. They claim that if they dont sell an adapter for a transmission, it is because it probably cant handle a bigger engine like the one you are going to put in it. They do sell them for the AX-15.
-Christian
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #5 of 6 Old 04-18-2004, 08:26 AM
mbood82
mbood82's Avatar
*Disclaimer: This is only what I heard from friends with older Jeeps*
The AX5 is a pretty weak transmission. The AX15 however is pretty strong. I have a couple friends with the 4 cyl in their wranglers and they killed the tranny's pretty quick in some cases. If you are going to go all out and do a 262 or 350 swap, you may as well drop in a stronger tranny. Either find an AX15 or an NV3500 (I think that's what they put in the later S10s behind the 4.3)
'99 Jeep Cherokee - RE 3.5" SuperFlex with 32s
'06 Dodge Magnum R/T
'03 Toyota MR2 Spyder
mbood82 is offline
post #6 of 6 Old 04-18-2004, 11:47 AM Thread Starter
slayer2000
slayer2000's Avatar
Well I guess an auto will do. I just don't have the budget for a new trans. The jeep deal fell into my lap maybe someone will drop in a 4.0 ,ax15 combo . Thanks for the info guys.
8.25 Strength joec89 XJ Cherokee Technical Forum 17 04-11-2009 02:27 PM
97+ E fan strength xjman4life XJ Cherokee Technical Forum 3 08-01-2008 07:34 PM
1997 8.25 strength ? newbs XJ Cherokee Technical Forum 15 05-13-2008 08:54 PM
D35 Strength Testimony keeth1123 XJ Cherokee Technical Forum 7 02-26-2008 10:02 AM
Strength of a D35? Meatroach XJ Cherokee Technical Forum 25 07-31-2006 04:26 PM
