Aw4 transmission problems - JeepForum.com
post #1 of 4 Old 09-30-2006, 06:00 PM Thread Starter
littlefriend
I just put a new engine in my cherokee. When i pulled the old one out the torque a verter came out with it so i put it back in when i put in the new engine. After i re-installed the engine i also replqaced the filter in the tranny. Before i replaced the engine the transmission worked fine and now it wont even go into gear. Any ideas as to what could be wrong.
littlefriend is offline
post #2 of 4 Old 09-30-2006, 06:11 PM
83iS
Sounds to me like the T/C isnt locked into the pump in the front of the trans properly. In order to fix this and the easiest way to fix it is, drop the trans and disconnect the T/C from the Flex disk on the engine. Then with the trans and T/C seperated from each other push the T/C onto the input shaft of the tranny and turn it, you should feel the T/C go into the tranny more and there should be a prositive clunking sound. Now when you spin the T/C it should take more effort because it is properly engauged with the tranny pump.
I hope that helps and i didnt confuse you.
Kyle
1999 XJ Limited.... R.I.P 10/27/06
1998 XJ Classic, stock for now.
83iS is offline
post #3 of 4 Old 10-01-2006, 09:56 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Look around at this page of the JeepForum http://www.jeepforum.com/forum/f11/tech-faq-links-tsbs-89273/
and you will find AW4 tranny info.
The neutral safety switch may need adjusting.
CJ7-Tim is offline
post #4 of 4 Old 10-01-2006, 11:07 AM Thread Starter
littlefriend
when i reinstalled the t/c i made sure that it ingaged the oil pump. of course this was after i had dropped the transmission because it wasn't working.
Transmission problems kfletch XJ Cherokee Technical Forum 5 05-16-2008 02:28 PM
HELP transmission problems XJGreaseMonkey XJ Cherokee Technical Forum 1 01-23-2007 09:49 PM
transmission problems mltryman21 XJ Cherokee Technical Forum 2 09-08-2006 08:19 AM
Transmission Problems RAA XJ Cherokee Technical Forum 3 02-24-2006 08:35 AM
transmission problems macro XJ Cherokee Technical Forum 2 09-16-2005 11:23 AM
