AW4 Transmission Manual Shift Modification - Operation Questions - JeepForum.com
post #1 of 12 Old 03-30-2011, 09:24 AM Thread Starter
chainerx
http://articles.jeepforum.com/XJ_AW4_TCU_Shift_Mod
I'm thinking of doing this mod, but do I need the torque converter lockup switch if i want it mostly to have more control over engine braking on longer downhills?
Also when should I use the TQ lockup switch other than at cruising speed on the highway? What are the advantages of the TQ lockup switch?
Lastly, can the check engine code it will throw on a '97 up be hidden so I'd be able to see the check engine light come on for any other issues?
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #2 of 12 Old 03-30-2011, 01:52 PM Thread Starter
chainerx
Anyone have any input?
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #3 of 12 Old 03-30-2011, 01:54 PM
Vassago
get over on naxja in the jeepspeed section, they'll be able to help you out
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #4 of 12 Old 03-30-2011, 02:42 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by chainerx View Post
...I'm thinking of doing this mod
Why ?
...i want it mostly to have more control over engine braking on longer downhills....
Simply put the transmission selector in 3 instead of OD. Overdrive will be disengaged and you will have engine braking.
... can the check engine code it will throw on a '97 up be hidden so I'd be able to see the check engine light come on for any other issues?
Probably not.
CJ7-Tim is offline
post #5 of 12 Old 03-30-2011, 04:59 PM
KF4SQB
1994 XJ Cherokee
The torque converter locks up on its own. If you are looking at the place I think you are looking at for the info, the poster incorrectly states that the converter normally only locks up at WOT. This is simply not true. If your converter doesn't lock up during "normal" driving, something is wrong. Start off "normally", and pay close attention to the shifts. You should feel a shift from 1st to 2nd, 2nd to 3rd, 3rd to overdrive, then one more "shift". This last "shift" is the converter locking up. The TQ mod is completely useless, and can easily cause driveability issues if you forget to turn it off when slowing down. The shift mod, on the other hand, I can see a use for. You can easily do one without the other.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #6 of 12 Old 03-30-2011, 07:21 PM Thread Starter
chainerx
Thanks for the explanation. So on the freeway the TQ is normally locked at cruising speed, 65-70mph?
I'm going to be moving about 1,000 miles soon, so if the TQ switch would get me 1-3 more freeway mpg I'd save a decent amount of money in short order.
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #7 of 12 Old 03-30-2011, 07:51 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
I have this mod (from AWShfiting) on my Trail-Only XJ. It's a great mod for the trails, but fairly pointless for street driving. The TC lockup switch will do nothing but possibly damage your tranny if you forget it's on.
I would suggest skipping the mod all together, unless you like looking at the CEL.
If you have any more specific questions, I can try to help you out. I have been running it for a few years.
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #8 of 12 Old 03-30-2011, 07:56 PM Thread Starter
chainerx
Is the CEL going to be always on, or will it only come on when the switch is flipped?
I'll probably use it rather seldom, so if it only throws a code when used I can clear the code when I'm done using the switches that day with my cheap code reader.
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #9 of 12 Old 03-30-2011, 07:57 PM
Millermagic
You do NOT want to use a torque converter clutch to help you slow down. They aren't made for that kind of use.
In an emergency, lets say, you lose the brakes. You'll drop the auto trans in 1 in an attempt to stop. That's what it does, goes in the lowest gear it can and locks the torque converter. Not the best for anything.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #10 of 12 Old 03-31-2011, 12:38 PM Thread Starter
chainerx
Does anyone know if the CEL would always be on, or only when one of the switches is flipped (until the switch is flipped off and the code cleared with a reader)?
1990 XJ -Sold
1997 XJ -Sold
1998 XJ -Current DD
chainerx is offline
post #11 of 12 Old 03-31-2011, 06:57 PM
KF4SQB
1994 XJ Cherokee
CEL should only come on when you use the mod. With the switches in the "normal" position, everything is "original".
KF4SQB is offline
post #12 of 12 Old 05-21-2015, 12:36 AM
MondayWarriorZJ
zj?
will these mods work on a zj?
MondayWarriorZJ is offline
aq4 , aw4 kit , manual , manual lockup , shift kit , shifting , tcu mod , xj
96 to 97+ Modification Questions billabongopblue XJ/MJ Cherokee Non-Technical Forum 2 07-13-2009 11:40 PM
Manual Transmission Lift Questions beefsupreme XJ Cherokee Technical Forum 5 03-09-2009 03:30 PM
AW4 manual shift Mudbuggy XJ Cherokee Technical Forum 8 06-22-2006 03:32 PM
4x4 operation questions from a newb MPETESS10 XJ Cherokee Technical Forum 4 04-29-2006 12:26 AM
Shift your AW4 like a manual! savage1978 XJ Cherokee Technical Forum 13 11-10-2005 08:45 PM
