AW4 Transmission help please - JeepForum.com
post #1 of 8 Old 03-30-2013, 07:32 PM Thread Starter
Nhagar
ok I have a 98 Cherokee 4.0L with auto trans.
Ok I need help with this thing. When I put it in OD postion and go. I can feel it shift through the gears but when I get to say 50mph I am running 3000-3500 RPMs. If I let off the gas the rpms instantly drop to 1500rpms. Now if i get on the gas just a bit to get the rpms up to 2000. The motor revs but its not pulling/accelerating. if I give it more gas I can then fill it start pulling again at the 3000 rpms again.
Now if I get up to 50mph and rpms are high if I let off the gas rpms drop to 1500. I can then manually put the shifter into 3 position and then the rpms jump up and it downshifts into 3rd.
so I know it is or assume it is shifting through all the gears.
What can I do to get the OD to work and be able to drive 50+mph without over revving the motor?
I have replaced TPS and did the adjustment trick.
Need to know if I can fix or if Rebuild is in the near future.
Nhagar is offline
post #2 of 8 Old 03-31-2013, 10:24 AM
M35A2
1995 XJ Cherokee
What size tires are on it?
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #3 of 8 Old 03-31-2013, 11:07 AM Thread Starter
Nhagar
they are stock wheels and tires. well actually I think that maybe I went from 225 to 235's so I could get 8 ply tires instead of 6 ply.
Nhagar is offline
post #4 of 8 Old 03-31-2013, 11:13 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Did you install a genuine Jeep TPS, or did you install some crappy Chinese "Lifetime Warranty" junk ? Cheap crappy "Lifetime Warranty" parts are often out of specification or even failed right out of the box. Many times they have a short service life before they fail. Always buy top quality replacement parts and genuine Jeep sensors.
Make sure your transmission fluid is clean, and filled to the correct level. The AW-4 transmission uses Dexron-III/Mercon transmission fluid. Any other transmission fluid type may cause strange shifting.
Go here - http://www.jeepforum.com/forum/f11/t...ks-tsbs-89273/ - and find the AW-4 Service and Diagnostics Manuals. Perform the tests and follow the diagnostic procedures.
CJ7-Tim is offline
post #5 of 8 Old 03-31-2013, 11:40 AM Thread Starter
Nhagar
i have bought both the cheap one from autozone and one from dodge dealership. I did change fluid after issue started. it is correct fluid and filled.
I will look over link and see what i find thanks nathan
Nhagar is offline
post #6 of 8 Old 04-09-2013, 09:40 PM
M35A2
1995 XJ Cherokee
The kick down cable might need adjusting.
M35A2 is offline
post #7 of 8 Old 04-09-2013, 10:05 PM
Paradise XJ
1988 MJ Comanche
Like so:
http://naxja.org/forum/showthread.php?t=1015963
Possible, but the TPS controls the kickdown (thanks, cruiser54) this is the Throttle Valve adjustment...still important.
Tim is on the right track...sounds to me like your torque converter isn't locking up...or a solenoid problem, easily fixable. I had a similar problem on my Volvo...except the OD solenoid cost me $150+
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #8 of 8 Old 04-10-2013, 02:03 PM Thread Starter
Nhagar
well I have looked up the shifting solenoids and they seemed to be in the $125ea range and there are 3. question is replace all three and get it over with or chance it one doing just the one.
also are there cheper ones than 125ea? let me know thanks guys.
Nhagar is offline
