AW4 Fluid Capacity - JeepForum.com
post #1 of 16 Old 08-19-2008, 10:11 AM Thread Starter
Agent 000
Agent 000's Avatar
AW4 Fluid Capacity
I need to try to correct a problem with the transmission on my 98 XJ. I've got a Check Engine light on, and it keeps reading the Transmission Shift Module when I get it checked. This morning on my way to work, the transmission would not shift into overdrive (never had this problem before). Before I spend hundreds of dollars trying to correct this, I'm going to try the cheap method first. When I check my transmission fluid level, I cannot ever get a good reading when it's at operating temperature. I'm concerned about the fluid level being the cause, as I've got a leak in one of the transmission cooling lines (yes, I know, replace the line). What I want to do is drain the transmission tonight, and then refill with the proper level of transmission fluid, and see if that makes it work.
What I need to know, is what is the proper amount of transmission fluid to add, after draining the transmission (only puling the drain plug, not dropping the pan and replacing the filter)? Or, if there is something else I missing,please let me know what to check, or what to do. Thanks!
Chili Pepper Red 1998 Jeep Cherokee Classic
Agent 000 is offline
post #2 of 16 Old 08-19-2008, 11:16 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Automatic Transmission
4.0L AW4 - Drain and Re-fill about 3 to 4 Quarts (3.8L) Mopar ATF or equivalent Transmission Fluid labeled Dexron III/Mercon.
Filter and complete fluid exchange - 8 Quarts (7.8 L)
CJ7-Tim is offline
post #3 of 16 Old 08-19-2008, 07:37 PM Thread Starter
Agent 000
Agent 000's Avatar
Thank you for the information. Changed out the old fluid, put some hose clamps on the leaking cooling line fitting, and it seemed to do the trick.
Old fluid was beginning to develop a brownish red tint, rather than bright red, so not sure how long it had been in the transmission (I've owned the XJ for 21,000 miles now). Took it out on the road, the overdrive is working again, and the check engine light is off. This weekend, I'm going to pull the NSS off, clean it, regrease it, and that should solve it's problems.
post #4 of 16 Old 08-19-2008, 08:21 PM
CJ7-Tim
CJ7-Tim's Avatar
If you didn't do a 100% fluid change, drain the pan and add more fresh fluid in about a week. Do that again in another week and you will have drained almost all the old nasty fluid. Brown or burned smelling fluid is not good.
CJ7-Tim is offline
post #5 of 16 Old 08-19-2008, 08:29 PM Thread Starter
Agent 000
Agent 000's Avatar
For sure, figure while I'm at it, will try to replace the bad cooling line at the same time (will have to stop at NAPA to order one).
Just couldn't bring myself to pick up the store brand ATF, opted for the Castrol (was on sale for the same price as the Advance Auto brand). Figured it would do a better job of cleaning the transmission passages. Will have to pick up a few more quarts this weekend.
post #6 of 16 Old 08-19-2008, 11:25 PM
EricsXJ
The Post man
EricsXJ's Avatar
I can never get a good reading on mine either.
When I drain I measure exactly how much came out. That's how much goes back in.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #7 of 16 Old 08-21-2008, 05:31 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Another drain/refill is a very good idea. I just did mine and got a bit over 3 quarts out of it by just draining the pan. I started it briefly and moved the shift lever through all of the gears VERY quickly while up on the ramps and that brought the total fluid replacement to about 4 quarts.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 16 Old 08-21-2008, 06:36 PM
AZ Jeff
2014 JK Wrangler
Automatic transmissions with dipsticks are filled by DIPSTICK READING, NOT by stated capacity. The stated capacity is only a GUIDELINE for how much to use on refill.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #9 of 16 Old 08-22-2008, 06:08 AM
L20KEV
if going from DexII to III, do u need to do a full change or can they mix by doing a quick drain&fill?
L20KEV is offline
post #10 of 16 Old 08-22-2008, 07:41 AM
smokingun45
YMMV, but I drained and refilled (thru the drain plug) my AW-4 six times to clear the tranny of most of the old fluid and each time it used +/- 2.5 quarts af DEX. I bought Shell DEX III as it is a name brand and was also the least expensive. Good Luck!
smokingun45 is offline
post #11 of 16 Old 02-01-2009, 03:52 PM
jjg214
ok, well what are the ramifications if i use the drain refill drain refill etc etc method, and the PO had ATF 4 in the transmission instead of the dex/merc which is the right fluid, that im putting in?
jjg214 is offline
post #12 of 16 Old 02-01-2009, 05:00 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Doing the drain refill, run, drain, refill, run for three or four times will get the most of it out.
xjfever is offline
post #13 of 16 Old 02-01-2009, 05:50 PM
AZ Jeff
2014 JK Wrangler
Statistically, five drain and refills of the pan, with running in between, will result in about 95% new transmission fluid being present, with only about 5% of the bad stuff still circulating in the system.
AZ-Jeff
AZ Jeff is offline
post #14 of 16 Old 02-01-2009, 07:25 PM
jjg214
i plan on using that method, let me clarify my question... is there adverse affects from mixing ATF and Dex/Merc in this process? because i am putting dex/merc in there but i have no idea what the previous owner or shop he took it to put in it. i would hope its no ATF but you never know.
jjg214 is offline
post #15 of 16 Old 02-01-2009, 08:31 PM
AZ Jeff
2014 JK Wrangler
There should be no adverse effects from mixing types of ATF. Just drain and replace enough to insure that almost all the old crud is gone.
AZ-Jeff
AZ Jeff is offline
Power Steering Fluid Capacity Magus2727 XJ Cherokee Technical Forum 4 08-29-2017 07:45 AM
1994 Jeep Cherokee Transmission fluid capacity?!?! JeepCherokee513 XJ Cherokee Technical Forum 4 07-09-2009 03:31 PM
91' XJ Brake Fluid Capacity? - i searched the wiki and all posts warrior_oh58d XJ Cherokee Technical Forum 6 02-10-2009 10:02 PM
AW-4 Fluid Capacity FguyTJ XJ Cherokee Technical Forum 4 05-11-2007 11:34 PM
1998 pwr steering fluid capacity Kamaaina XJ Cherokee Technical Forum 2 12-06-2006 03:09 PM
