AW4 downshifting question - JeepForum.com
post #1 of 10 Old 01-23-2014, 02:48 PM Thread Starter
sAe23
1995 XJ Cherokee
Not sure if this is a symptom or a feature...
When slowing to a stop with the transmission in OD, there is no discernible downshifting. It feels seamless all the way to a dead stop.
When doing so in drive ("3"), it is very noticeable that the transmission has shifted down to 2nd and then 1st.
This is happening while driving on "city" streets, slowing to a stop (not aggressively), during the last few car lengths before coming to a stop.
The trans fluid is in good condition and at the proper level...
Any thoughts (relevant to the topic!)?
TIA
sAe23 is offline
post #2 of 10 Old 01-23-2014, 02:59 PM
srk2881
1993 XJ Cherokee
It's a feature. Put it 1-2 you'll really feel it then
srk2881 is offline
post #3 of 10 Old 01-24-2014, 02:26 PM Thread Starter
sAe23
1995 XJ Cherokee
Can't exactly be driving around at normal speeds in "1-2" now can I
sAe23 is offline
post #4 of 10 Old 01-24-2014, 03:37 PM
Timo_90xj
Timo_90xj's Avatar
Nope, but when slowing down you can I remember having my 35s chirp in dry pavement being in 1-2 when the tranny shifted to first.
One recommendation: do not use 1-2 in icy/ snowy weather
***Under construction***
Timo_90xj is offline
post #5 of 10 Old 01-24-2014, 08:46 PM Thread Starter
sAe23
1995 XJ Cherokee
Thankfully, there is no icy weather in the greater Los Angeles area
And this is happening while letting the transmission do the shifting.
The only difference is between being in "OD" and "3"...
sAe23 is offline
post #6 of 10 Old 01-27-2014, 08:20 AM
frhrwa
Fish'n Fool
frhrwa's Avatar
not sure of the gearing difference when in a gear vs OD, but mine also does the free spin if your in OD slowing down.. just floats down.. but.. if your in a gear like 3rd, it downshifts... along those lines, my ford SD does the same thing, free spins slowing in OD, but slows you if in 3rd..
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #7 of 10 Old 01-28-2014, 03:25 AM Thread Starter
sAe23
1995 XJ Cherokee
Cool, thanks.
sAe23 is offline
post #8 of 10 Old 01-28-2014, 07:33 AM
Kalali
Do you guys call "D" OD or I'm missing a gear in mine!!?? Put it in D and drive. what am I missing?
Kalali is offline
post #9 of 10 Old 01-28-2014, 02:46 PM
Agony Wagon
1995 XJ Cherokee
OD is a popular cartoon character frequently used to adorn various parts of one's vehicle. He is a friend of the cartoon character Garfield.
OD Antenna Ball:
Agony Wagon is offline
post #10 of 10 Old 01-29-2014, 02:52 AM Thread Starter
sAe23
1995 XJ Cherokee
Unless your year is different than my 95, the "D" on the shifter plate has a circle around it, and when you drive with the shifter in this position, it allows the transmission to upshift into overdrive as needed. The "3" position limits it to the 1:1 ratio, which is often referred to as "drive", but I may have mis-used the term in this post/context
sAe23 is offline
