AW4 to ax15 swap - JeepForum.com
post #1 of 6 Old 02-13-2014, 07:35 PM Thread Starter
2000jeep06078
AW4 to ax15 swap
I have done a lot of homework and it should work good but just wanna put the idea out for inspection. I have a 2000 XJ 4.0 auto (AW4 I believe). I want to swap in an AX15 Terminator. I know its a lot but I prefer driving standard that much. I know the NV3550 is ment for the 2000/2001 and the AX15 went in the 99. But it should be fine cause the 99 and the 2000 has the same engine except for the distributerless ignition and the same body. Unless there is a difference in the interior and something will be in the way of the shifter. This rig is my DD and only will see light to moderate trails. I don't want to use the NV3550. It seems to have inherent grinding, popping, general loudness issues. Any thoughts?
2000jeep06078 is offline
post #2 of 6 Old 02-15-2014, 08:06 PM
rjbruzan
I have owned Jeeps with both trannys and they are both good. I will say the AX-15 did shift nicer. Id have no problem running either. Will you be getting a PCM from a manual trans XJ .
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3 of 6 Old 02-16-2014, 07:24 AM Thread Starter
2000jeep06078
That is one aspect I haven't thought out. I thought I just needed to rewire the neutral safty switch. Do I need to change the PCM?
post #4 of 6 Old 02-16-2014, 08:11 AM
rjbruzan
You will get check engine lights for Torque converter and not showing what gear its in. Also no backup lights . The correct PCM and trans wiring harness will make the job easier and better. Buying a quality trans is a wise decision. You dont want to be needlessly bothered by problems. Be sure to use a bellhousing that has an exterior throw out bearing slave cylinder.
rjbruzan is offline
post #5 of 6 Old 02-16-2014, 02:23 PM
Vassago
make sure you get a 2000 and up 5 speed PCM, i've wondered but havent looked into seeing if a PCM from a TJ would work, as there are more 5 speed tj's out there than 00-01 XJ's
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #6 of 6 Old 02-17-2014, 07:20 AM Thread Starter
2000jeep06078
Yeah I'll have to check too. I wonder if the pcm and any wiring is tranny specific cause the default 2000 5speed is NV3550 and I want to put in the AX15 terminator. I shouldb't have a problem with the bell housing
2000 xj , ax15 , swap
