Quantcast AW4 ATF Change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > AW4 ATF Change
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 01-28-2006, 06:04 PM   #1
cobra7
AW4 ATF Change
Am I correct in that to change the fluid in the AW4 tranny of a 2000 XJ, you have to remove the pan and also change the filter mounted on the valve body?
Dealer told me that I shouldn't remove the pan cause there's a drain plug and it's just a drain and fill operation. I think they might have been assuming that it's a Chrysler tranny, though. I don't see a drain plug on my tranny anywhere and Haynes says to remove the pan to drain the ATF. Dealer also said that the stuff used to seal the pan back up is $125 per tube. Haynes says it's just a gasket and filter that is needed.
Who do I believe? What's the correct answer?
COBRA7
[SIZE="1"]2000 XJ Classic (Black on Camel) | 4.0L I6 | AW-4 | NP231J | Dana 30 | Chrysler 8.25[/SIZE]
cobra7 is offline   Reply With Quote
Old 01-28-2006, 06:40 PM   #2
Grumman
125.00 per tube . that dealer is blowin BS. black RTV doesnt cost that much.
Grumman is offline   Reply With Quote
Old 01-28-2006, 06:51 PM   #3
AZ Jeff
The AW-4 has a drain plug, unlike most other auto trans. This makes draining and refilling just the pan fluid a snap.
The filter in most auto trans is merely a fine screen mesh. It's not a filter like the one in the engine oil system, or the fuel system filters. Thus, replacement of that filter is not critical, unless the trans has been mistreated, and the pan contains all kinds of gunk and foreign matter.
Unless you are unsure of the condition of your trans, I would not drop the pan to change the fluid, and would just pull the plug. Now if the trans is suspect in any way, then dropping the pan, cleaning or replacing the screen filter, and refilling thereafter might make some sense.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 01-29-2006, 08:28 AM   #4
cobra7
I don't think the dealer was saying that ultra black RTV cost $125. They were saying that there was some other special stuff that was used that cost $125.
So, if I do want to drop the pan and replace the filter, can I just use the gasket/filter kit that I got at Pep Boys, or do I need to put anything else on the gasket to seal it up, like RTV for example?
Thanks!
COBRA7
Old 01-29-2006, 10:09 AM   #5
Grumman
Thanks!
Dont see why not.
http://www.partsamerica.com/ProductDetail.aspx?categorycode=3289&mfrcode=PTX&m frpartnumber=22072 suggested uses
used it before on transmission and oil pan seals/gaskets with no problem
Old 01-29-2006, 11:07 AM   #6
cobra7
Cool, yeah that's exactly the stuff I got yesterday. So I'll just put a layer of that stuff on the pan, then put the rubber gasket on top of it, then push onto the tranny.
I'll give this a shot. Thanks!
COBRA7
Glock Forum
