03-04-2010, 05:32 PM
#91
just pulled a switch that im using. opened it up and reset the led so earth would actually be the positive end. put the little resistor it had in line with it and tried it. didnt work.
think i am going to get a NO relay and try it that way. just need to find the right one
[CENTER]I take what i want from posts, and interpret them the way i see fit. If it's wrong, oh well[/CENTER]
[CENTER]You'll get over it[/CENTER]
[SIZE="1"]"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire[/SIZE]
03-05-2010, 12:17 PM
#92
Set up my LED switch to send power to a relay.
On relay - have the b/p wire going to pin 85, ground going to 86. ground going to 87 and hot going to 30
LED lights up, fan comes on, no CEL
–Voltaire[/SIZE]
03-05-2010, 12:46 PM
#93
Awesome info. I dunno how I missed this thread in the past.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - DD/Light Trail Rig - The War Wagon
75 CJ5 with a badly chopped CJ7 Tub - Pandora
03-12-2010, 03:32 PM
#94
I just did this mod on my 96 and it sets the CEL. So....If someone could elaborate on the relay setup that Apostle described a couple post up, I would appreciate it. One thing I don't understand for his configuration, do you cut the db/pk wire or just tap into it. If you cut it, what terminals on the relay do the now 2 db/pk wires go to on the relay?
Any help would be appreciated.
Greg
1996 Cherokee w/D44 in rear, SYE, 33" BFG Mud Terrain, Custom 4x4 Fabrication bumper up front carrying a Warn 8274, coming soon - home built rear bumper w/tire carrier
03-12-2010, 07:25 PM
#95
First off I apologize to Buckeye for stealing his diagram for a start
Here is Apostle's diagram.
This should be no different that a switch.
THIS should cure the CEL
95' XJ Country - Stock Skids - Limited Slip Rear Diff
Off Road Package - 4.0 HO - AX15 - NP231
Repeal Ohms Law!!!
Originally Posted by Azzy
You can tell the character of a person in how they treat someone who can do nothing for them.
03-12-2010, 08:18 PM
#96
yeah, didnt cut mine. cut off about 1/2" of the wire cover, then wrapped the new and soldiered it.
–Voltaire[/SIZE]
03-12-2010, 08:41 PM
#97
Thanks guys. I will try one of these tomorrow.
Greg
03-12-2010, 09:37 PM
#98
Could it be done this way also to include a 3-way switch so that the fan can be turned off?
03-13-2010, 06:27 AM
#99
thanks for the info
03-13-2010, 07:34 AM
#100
yes, would involve a bit more wire running, but is very doable.
That would be a good setup for water crossings, however if I have to cross water I shut the jeep off and let it cool a while, and usually wade the crossing to make sure I wont be surprised. Then I remove the fan relays and head across.
Repeal Ohms Law!!!
03-13-2010, 10:34 AM
#101
Holder350,
I agree about crossing the creek on foot to avoid surprises. Now you got me thinking on pulling the fuses/relay. That may be a better option. Kind of hard to forget and leave it off that way.
Greg
03-13-2010, 11:27 AM
#102
Yep I am a forgetful bastard and I hate having anything that I can forget to leave on or off.
Repeal Ohms Law!!!
03-13-2010, 05:53 PM
#103
Can somebody tell me if I labeled the relay properly in this diagram? I'm lazy and more used to dealing with the number on a relay.
03-13-2010, 06:36 PM
#104
If you will give me a minute I will go out to my shop and get my sketch because I just completed this and I marked up my sketch just as you have but it is in my shop. Be back in a minute.
Greg
03-13-2010, 06:52 PM
#105
Here is how I did it. Another thing that is most likely different is if you have a three position switch, most of them will have the center position off instead of one of the end positions as I have indicated.
