#1 | |
Autopal H4 upgrade
Getting ready to order an H4 conversion kit. The only Autopals i can find on ebay are these
are those the ones that everybody uses?
#2 |
No, those ones are junk. Anything that says "diamond" in the title is the wrong thing.
=====_____ /__l_l_,\____\,___ l_---l_l__l---[o]llllll[o] _.(o)_)__(o)_)--o-)_) |
#3 |
nope, i have heard the diamond cut are not as good light pattern. The good ones look stock but have a really good light output. when you order them i wouldn't get them with the city light option it really messes with the highbeam pattern. it cuts a strip right down the middle. they look cool hooked up to the turn signal though
#4 |
I just ordered a set off EBAY also I went with the eCode pattern, i really doubt that the inspection shops can tell the difference, they may be shocked by the output but not gig me. either way I am gonna keep my old light around just in case.
#5 |
Go Jeepin
I bought my AutoPals from that seller. These are in his store and are the correct ones to get, the 200mm EURO -
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. Last edited by CJ7-Tim; 05-11-2009 at 09:44 AM.. |
#6 |
awesome, thanks!
#7 |
Me007, are you doing the head light wiring upgrade as well??
"Those who hammer their guns into plows will plow for those who do not"...Thomas Jefferson "Beware lest the Stone Age return on the gleaming wings of science." - Winston Churchill |
#8 |
Eventually, for now ill just use regular 55w bulbs anythings better then the stock lights, just another question. Last edited by Me007gold; 03-31-2009 at 06:18 PM.. |
#9 |
Any one get these with the "city lights" I know what the are, just want to see what they look like in an XJ.
I know they cut in to the high beam pattern, but all of my driving is in the "city" so my Highs are never really on |
#10 | |
#11 |
I had a cheap pair with city lights before I bought my autopals. They wouldnt fit in the factory light buckets with the city bulbs in, you would have to drill or cut a clearance hole for them. So I just taped ober the city bulb hole and ran without them.
#12 |
the city lights are just a little bulb in the bottom the main reason i got them is so that the hole would be there for if i wanted to put some strobes in or something. i still have the clear in but i am also going to try blue it will just give off a light blue glow. only problem is i have DRL's so they wont stand out as much.
#13 |
You won't notice to much of a difference unless you upgrade the harness as well. I put in the Rampage H4 conversion instead of the plastic conversions. I saw a small difference until I put in Bigoffroads.com upgraded headlight harness, what a HUGE difference!!!!!! Easy install and one of the most obvious differences I have ever seen in lighting! As far as city lights
![]() They don't put out any useful light.
2007 Rubicon Unlimited 2006 Commander "U" pkg., Dark Khaki, chrome grill, Mopar remote start. 1997 Cherokee SOLD!!!! :( :( :( |
#14 |
The harness (at least on mine) will make a bigger difference than the lights- even the cheap 14awg ebay harnesses. I'd at least throw one of those in at the same time as the lights.
I used this, which is suspiciously similar to BOR's "custom made" harness, for a lot less money. Pair of Autopal Ecodes with 60/55s. Cheap, works good. Better than my Silverstars and a lot better than stock sealed beams. |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
