Automatic transmission wont shift automaticly - JeepForum.com
post #1 of 4 Old 12-04-2009, 09:47 AM Thread Starter
for_givn
My automatic transmission wont shift automatically, It is stuck in Overdrive unless I shift it manually from 1st to 2nd to drive. Manually shifting is fine and no problems with the tranny but when left in drive when i start to drive it is in overdrive and I have to drop it in 1st and manually shift it as I drive. Anyone know why? It is a 1992 Jeep 4.0.
for_givn is offline
post #2 of 4 Old 12-04-2009, 10:14 AM
598BBC
Possibly the TCM.. Transmission control Module, located behind the glovebox, I had a similar problem and that was the cause.. there is a way to test it, you will have to search the forums for it.. hope this helps.
F-toy on Links 2.6 stroker, 4 sticks, rolling on 39" red labels, running on pane...95 YJ 4.0 A/T, 60s frnt and rear,4.56s,w/ ARBs, Atlas 4.3, 37" BFG Red labels, Full Black Diamond cage,.... 47 CJ2A 110"wb, 598bbc for power, 2spd glide, 17" travel, and a blast in the Dunes...
598BBC is offline
post #3 of 4 Old 12-04-2009, 12:28 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Most likely cause is the Throttle Position Sensor (TPS), especially if you recently crossed any deep water, ran a mud pit, or washed the engine. Test the TPS.
TPS Test
You should have 5 volts going into the TPS. At idle, TPS output voltage must be greater than 200 millivolts. At wide open throttle (WOT), TPS output voltage must be less than 4.8 volts.. The best is to use an analog meter (not digital) to see if the transition from idle to WOT is smooth with no dead spots. With your meter set for volts, put the black probe on a good ground like your negative battery terminal. With the key on, engine not running, test with the red probe of your meter (install a paper clip into the back of the plug of the TPS) to see which wire has the 5 volts. One of the other wires should show .26V (or so). The other wire will be the ground and should show no voltage. Move the throttle and look for smooth meter response up to the 4.49 at WOT.
Perform the test procedure again and wiggle and/or tap on the TPS while you watch the meter. If you notice any flat spots or abrupt changes in the meter readings, replace the TPS.
CJ7-Tim is offline
post #4 of 4 Old 12-04-2009, 06:01 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Do the 1992s have the TCU fuse taped up under the passenger side dash like the older models? If so, check there.
cruiser54 is offline
Cold transmission wont shift out of 1st gear sAe23 XJ Cherokee Technical Forum 38 07-01-2013 07:51 PM
1991 transmission wont shift in proper gear corbin9191 XJ Cherokee Technical Forum 6 01-27-2009 12:11 PM
Automatic or straight shift imaslammer XJ Cherokee Technical Forum 19 06-02-2008 09:02 PM
Shift Knobs for automatic transmissions 98tXJ XJ Cherokee Technical Forum 23 03-21-2007 08:18 AM
Automatic Shift Knob? Lagooz00XJ XJ Cherokee Technical Forum 9 12-02-2004 04:12 PM
