The Automatic to Manual Swap Thread
#61 | |
I've got a queston for those who have done this. I have a 90, my parts jeep is a 95. Now will the crank postioning sensor work from the 95 onto the 90?
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. With a jd yellow paint job |
#62 |
Does anyone know?
#63 |
Hey bro can you log into your photobucket so i can see the pictures? Lol thanks
#64 |
#65 |
ok i did this swap, but now my jeep doesnt start, new cps, but it still cranks and wont fire. Do i need the ecu from a manual, or will it work with the auto ecu? please any help would be great.
#66 |
i forgot to add it a 90
#67 |
Sorry to be a pest to the forum but i would just like to know I'am not just wasteing money.
#68 | |
did everyone have to cut down the transmission input shaft to do this swap? |
#69 |
Man .. great job for taking on this project ..
#70 |
thanks for this for im debating on doing the same swap.
She's a 96, 4.5 inches on 33's. 30 front, 44 rear, armored & wishin i can wheel it like i stole it. my build http://www.jeepforum.com/forum/f11/96-perrywinkle-build-thread-634491/ |
#71 |
ok so i swapped the ax15 with good 4.0 98 xj into a 2000 aw4 with blown 4.o // everything basically is set up but the nss bypass... it is pretty clear what needs to be done with that... what about the clutch safety switch...is that used or do i disregard that since the nss is being set up and that will bypass the css?
#72 |
I did this swap to my 96 and i disregarded the Clutch saftey switch and it hasn't given me any problems. And one other thing i am not sure if it mentioned in this write up is Reverse light on and Aw-4 they come on through the Nss But the Ax-15 has it on set of wires that run to wiring harness. For mine when i got the tranny out the junk yard i cut the wire off the harness in the junk yard that runs down the pass side and connects to the a set of wire on the side of the tranny. Since i bypassed the Nss conecting the 2 wires together i thought that if i connected the Ax-15 reverse light wire to the Nss wire that make the revese lights come on i Believe that is was A and E on the connector and it works great.
#73 |
well i am using the harness that went with the 98 manual and 4.o // so i guess the reverse lights are hooked in as we set that up the other day... the jeep still is not starting though....i got power, but i wont crank or turn over... exactly like the clutch is not pushed in...the wiring at the clutch is not together...if i connect the two wires at the clutch will it work, or do i need to use the NSS bypass to fake out the starter? thats what i think im gonna try next time i get to the garage? any comments?
#74 |
you need to bypass the NSS or trick it into thinking its always in N or something, kinda sounds like your problem if you havent touched it
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies 88' Cherokee Limited - RIP Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!! |
#75 |
Hi guys, i just finished this conversion a couple weeks ago. I am having some issues and was looking for some advice. The first problem is that when i down shift and then put the tranny in neutral the engine wants to stall unless i hit the throttle and then it idles fine. I saw someone else with this problem earlier in the forum and he was able to fix it but did not say how. The other problem is i am getting tranny codes, so i unplugged my tcm. No i am getting p1698 which is tcm not working code. Is there a way of tricking the pcm to think the tcm is connect, with out replacing the ecm with a manual one. My bigges problem is when i go to get my jeep inspected it will fail because of the check engine light on.
Thanks all |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
