Quantcast The Automatic to Manual Swap Thread - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > The Automatic to Manual Swap Thread
Old 02-12-2008, 06:47 AM   #31
jrsmith_80
1988 FSJ Cherokee
Very Nice Write Up. Loads of detail.
Whirl 'Em with Wisdom and Bedazzle 'Em with BS
jrsmith_80 is offline   Reply With Quote
Old 02-12-2008, 08:01 AM   #32
75SV1
Originally Posted by 92westshady View Post
Can someone tell me if there is a difference in the manual transmission or general systems of the '97-'99 Cherokees and the '00-'01?
I guess what I am asking is, if I am looking for parts to do a manual transmission swap into my 2000 Cherokee, will the AX-15 and other manual transmission parts from any '97-'01 work or should I be looking only for '00-'01 parts?
I have been browsing some transmission parts on ebay and some of the AX-15 listings say "will work for '89-'99" and I am wondering what if any differences there are between '99 and '00-'01?
I would appreciate some input if anyone knows. Thanks!
The '00-01' Cherokee should have an NV 3550 for the manual transmission. I'm not sure of the cross member for it. There is a difference between an XJ or MJ with an BA-10/5's cross member and one with an AX-15.
Tom
75SV1 is offline   Reply With Quote
Old 10-17-2008, 12:39 PM   #33
wslbry
1995 XJ Cherokee
my auto in my 95 xj just went, how long does it take to do this swap?
wslbry is offline   Reply With Quote
Old 10-17-2008, 01:11 PM   #34
Mr_Random
1986 XJ Cherokee
Originally Posted by jfman View Post
Quick and maybe stupid question
Can you use an manual trans from a 2wd jeep???
Yes but you'll have to remove the tail shaft extension and acquire t t-case with matching splines.
I'm sure the pilot bearing came with the clutch kit, mine had it...
Originally Posted by ceb0217;
I live with in an hour of the coast so getting sea foam is easy, but isnt the salt bad for the fuel system??? and how about the people that live farther away can you just foam up water and sea salt ??? if so what kind of mix do I use ??? 1table spoon to a gal of water??? and then how do I "foam it up" mabe a little soap????
Jeepus buildicus:
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/
Originally Posted by jgorm View Post
Using pure N2 is a total waste of money considering you can get 78% nitrogen for free.
Mr_Random is offline   Reply With Quote
Old 11-24-2008, 05:39 PM   #35
OtsiderCherokee
2005 WK
I have a 5-Speed and all the necessary parts from a 1989 Cherokee. Is it possible to swap that transmission into my 1999 Cherokee Sport without running into a whole bunch of problems? My automatic is working fine at the moment, but I want to be prepared for the time of WHEN it goes out, I hate automatic transmissions...
OtsiderCherokee is offline   Reply With Quote
Old 11-24-2008, 06:04 PM   #36
Mr_Random
1986 XJ Cherokee
If you have a 231 now, the splines may not match, but if you have the 89 231 also, the speed sensor and 4wd switch should swap over (I think). Same to be said if you have two 242's (I think). I don't know what will happen if you have two different t-cases...
But holy old thread! Loaded with good info, obviously, or it wouldn't keep coming back like this...
Jeepus buildicus:
http://www.jeepforum.com/forum/showthread.php?t=757079
Old 11-24-2008, 06:36 PM   #37
OtsiderCherokee
2005 WK
I have the NP231 out of the 89 as well if I would need it.
You are right, this thread is LOADED with great info.
Old 12-14-2008, 11:54 PM   #38
Lycaon
im doing virtually the same thing, 89 AX15 into my 98 XJ. as far as my research shows me, the 89 ax15 will match with my 98 np231. will i have to move my crossmember closer to the front of the vehicle and are there provisions for a neutral safety switch after the manual is swapped in or should i just leave it without one
Lycaon is offline   Reply With Quote
Old 12-15-2008, 07:56 PM   #39
shawnxj
1988 XJ Cherokee
prolly a dumb question but why do you need a new master cylinder?
shawnxj is offline   Reply With Quote
Old 12-15-2008, 08:12 PM   #40
Mr_Random
1986 XJ Cherokee
Ummmmmmmmm.... automatics don't have master (or for that matter, slave) cylinders. Yup... there's your need for a new one!
Jeepus buildicus:
Old 12-15-2008, 08:30 PM   #41
shawnxj
1988 XJ Cherokee
ugg so these are hydraulic clutches that sucks. i was expecting them to have mechanical clutches and thought you were trading out the brake master cylinder for some unknown reason
Old 02-09-2009, 09:09 PM   #42
Absolutexero
my only question is, on the obd-II's do you run into problems with the ECM? I have read up on some other swaps such as a 3800 with a manual into a fiero (my other love) which requires some modification to the wiring to the ecm because AFAIK all 3800s were mated to automatic trannys and the ecm wouldnt work with the manual tranny in the fiero without making modifications to the wiring harness and doing crazy things like soldering in resistors and even a lightbulb in one of the wires (to serve as a load so the ecm thinks the tranny is shifting). granted, it's a GM and not a Jeep but, i figured that the OBDII Jeep ecm's may have some kind of transmission shift detection or something.
Current: 1998 Cherokee Classic (White)
stock with 263k miles yay!
SOLD 1999 Cherokee Sport (Black)
~6" Franken-lift (2" CSS/ Rusty's 180lb 3" front springs, S10 bastard pack w/ 3" Rusty's AAL)
Absolutexero is offline   Reply With Quote
Old 02-09-2009, 09:41 PM   #43
Higgs98XJ
Higgs98XJ's Avatar
I've been waiting for this write up. Nice work! Now only if my auto transmission would crap out for some reason...
1998 Red XJ Sport
Sold :(
Now: Stock WJ Laredo
Future: Dad's WK Laredo
Higgs98XJ is offline   Reply With Quote
Old 02-09-2009, 11:01 PM   #44
1984XJ
1990 XJ Cherokee
Can you reverse this and go Manual - Auto?
.,_______.o_o.
//_|__l__,\___\,___
l_--\__\__l----[]llllll[]
_(o)_)____(o)_)--o)_)
Daily Driver Jeep #16
Utah Jeep'n
1984XJ is offline   Reply With Quote
Old 02-10-2009, 10:29 PM   #45
1984XJ
1990 XJ Cherokee
.,_______.o_o.
//_|__l__,\___\,___
Utah Jeep'n
Glock Forum
