Quantcast The Automatic to Manual Swap Thread - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > The Automatic to Manual Swap Thread
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full
Old 06-04-2006, 09:01 PM   #16
RickyN29
Though I love my automatic, I read your whole writeup. Very good job, I'm sure in the future many many people will be able to do this conversion because of your very clear write up.
Very nice contribution to the Jeeper Community.
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline   Reply With Quote
Old 07-07-2006, 08:41 PM   #17
Jeepin_XJ_101
Sorry guys I forgot the part about the linkage. I found my original papers I did the "prep work" on and all the sudden it clicked I forgot to add the linkage portion Yes there is linkage modification, dont worry its not too bad Anyways its updated in the original post under Reassembly Part II
"When in doubt... Floor it"
1989 XJ 4.0L I6 - AX-15 Swap - NP231 - 4" RC - 33x13.50 MT Claws
*SOLD*
2005 WK 4.7L 3.5" RK, 255/75R17 on Rubi Wheels
1992 YJ 4.0L 5" ProComp on 35x12.50 Trxus MT
Jeepin_XJ_101 is offline   Reply With Quote
Old 07-08-2006, 01:33 AM   #18
cyberbackpacker
What yard you going to? Pull-N-Save in Aurora? Man I miss that place... could always count on finding at least 4 or 5 good XJ's out there and prices were great.
For everyone else out there, here is an example of their pricing:
WEEKLY SPECIALS for JULY 8,9, & 10th
any REAR END - $27.99
any CYLINDER HEAD W/CAM - $17.99
any CYLINDER HEAD WO/CAM - $7.99
Craziness... you could potentially get a D44 for under $30 (I saw three in about two years... slim chance, but possible).
-Kevin
cyberbackpacker
cyberbackpacker is offline   Reply With Quote
Old 10-17-2006, 01:17 AM   #19
littlefriend
My Aw4 just crapped out and i have dicided to do this swap this weekend. Thanks for the pointers.
littlefriend is offline   Reply With Quote
Old 06-26-2007, 11:10 PM   #20
BS87
Great write-up. Probably shouldn't have read it because now i'm 99% going to do it
I searched, but nothing came up that answered me, so I fugured i'd ask in this thread, instead of starting yet another one.
I have a 95 xj, and i see the punch holes, however i have 3, so i'm just assuming the middle one is the center of the hole and the other 2 are the bolt holes.
However, these punches are just an inch above the large fuse box and its connector inside the engine bay and under the dash. I couldn't see from your pictures, but is the fusebox located there for you as well? Or for anyone whose done this on a later XJ, was there any clearence issues with the fuse box?
Also, i'll swap it if i must, but i'm kinda attached to my NP242, so were there ANY manuals that had the correct splines? If not, does anyone make an adapter, or am I fixed into using a 231 ( not neccesarily bad) ?
BS87 is offline   Reply With Quote
Old 06-27-2007, 04:54 PM   #21
BS87
Also, now that i think about it, and maybe yours is different because it's RENIX, but wouldnt the OBD1 computer have a fit when i hit overdrive speeds? I'd probably have to get the ECM from the manual cherokee as well.
Old 06-27-2007, 09:38 PM   #22
n20jeep
1993 XJ Cherokee
the obd1 engine computer has nothing to do with the overdrive in the Aw4
n20jeep is offline   Reply With Quote
Old 06-28-2007, 12:51 AM   #23
BS87
Awesome
Old 07-20-2007, 07:39 AM   #24
92westshady
Can someone tell me if there is a difference in the manual transmission or general systems of the '97-'99 Cherokees and the '00-'01?
I guess what I am asking is, if I am looking for parts to do a manual transmission swap into my 2000 Cherokee, will the AX-15 and other manual transmission parts from any '97-'01 work or should I be looking only for '00-'01 parts?
I have been browsing some transmission parts on ebay and some of the AX-15 listings say "will work for '89-'99" and I am wondering what if any differences there are between '99 and '00-'01?
I would appreciate some input if anyone knows. Thanks!
92westshady is offline   Reply With Quote
Old 07-20-2007, 10:41 AM   #25
XJohnnyC
1992 MJ Comanche
I saw no mention of the pilot bearing. Or maybe I just missed it.
You DID install a pilot bearing, right?
XJohnnyC is offline   Reply With Quote
Old 07-20-2007, 12:48 PM   #26
92westshady
I thought he said it came with the clutch kit, and he installed when installing the clutch?
Old 07-20-2007, 07:22 PM   #27
XJohnnyC
1992 MJ Comanche
That would be the throw out bearing. Different from a pilot bearing. Just wondering because it wasn't in the description or on the parts list.
Old 07-20-2007, 10:55 PM   #28
BS87
P.S. The more research i do, i'm pretty sure the Crossmembers are the same for Auto vs. Manual, atleast on the later models. Looks like the AX-15 just uses a plate that kinda bridges the "gap" between the tranny and crossmember.
Old 02-12-2008, 12:42 AM   #29
jfman
Quick and maybe stupid question
Can you use an manual trans from a 2wd jeep???
jfman is offline   Reply With Quote
Old 02-12-2008, 05:16 AM   #30
HeepToJeep
1982 CJ8
Excellent write-up, I feel the same way about my five speed.....regardless what XJ I buy next my AX is goin with me!
Wm
HeepToJeep is offline   Reply With Quote
Glock Forum
