auto shut down relay - JeepForum.com
post #1 of 1 Old 02-02-2005, 06:22 PM Thread Starter
Jeepsr4me
I drove my 2001 Cherokee about 36 miles this morning after filling up from empty. I got to where i was going. About 2 hours later i get in and crank up but it turns over but does not start. And there is this load buzzing noise coming from the engine area. I open the power dist box and the asd relay is making the noise. Also the fuel pump in the tank was buzzing but not as loud. I pulled the relay apart and noticed that it was working the relay very fast making the buzzing sound. When i manually pushed the relay switch in and had some one start it the Jeep fired up but a check engine light was on. How do i know if the relay is bad and not engaging fully or is there another issue causing the relay to trip at a fast rate?
Jeepsr4me is online now
Auto shut down after checking fuses Tjs88xj XJ Cherokee Technical Forum 8 07-11-2009 08:35 PM
check engine 463fuel level sending unit volts too high,138 auto shutdown relay circut 4x4xjCREW XJ Cherokee Technical Forum 2 12-10-2008 06:06 PM
Auto Shut Down 92blazn XJ Cherokee Technical Forum 8 11-14-2007 09:36 AM
OEM Fog lights...auto shut off with high beams? xjinga XJ Cherokee Technical Forum 3 02-12-2007 11:17 AM
auto windows won't shut off himarx XJ Cherokee Technical Forum 6 03-08-2006 08:11 PM
