Quantcast Aussie Locker 8.25" 29-spline Install Its here (almost) - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Aussie Locker 8.25" 29-spline Install Its here (almost)
Old 11-01-2008, 04:35 PM   #46
Bryson
Originally Posted by Ryan_25 View Post
Not sure what you mean by cocked, They were not drinking at all.
Its the shadows in the pic.
The gap between the left and right half of the locker is different on the top and bottom. Make sense?
In other words: the halfs look like this: / \ instead of: l l
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production - www.CortekSystems.com
Owner of Boostwerks.com
Website in development.
Bryson is offline   Reply With Quote
Old 11-01-2008, 04:39 PM   #47
XJLI
1993 XJ Cherokee
x2 on shadows. flash does funny things.
Factory Four Link
XJLI is offline   Reply With Quote
Old 11-01-2008, 05:36 PM   #48
Ryan_25
www.profenderusa.com
Sometimes I forget that sarcasim does not come across on these boards sometimes.
Its the shadows that make it look funny. They is an equal gap between the cam gears.
bluedogjeep.com
Blog bluedogjeep.wordpress.com
Ryan_25 is offline   Reply With Quote
Old 11-01-2008, 06:05 PM   #49
Bryson
Hrmm, I don't know how it's a shadow/camera issue when both the center and ends look offset. But hey, if you don't see a problem, I'll take your word for it.
Old 11-01-2008, 06:09 PM   #50
danw77
danw77's Avatar
Because they AREN'T offset. The flash creates a shadow that makes them LOOK offset, but in actuality they are parallel. Like this: | |, not this: / \
83 CJ-7, 95 XJ (SOLD), 99 XJ
Christian Jeep Club Member #217
1999 XJ For Sale - Lifted, Leather - PM for Details
or click here
danw77 is offline   Reply With Quote
Old 11-01-2008, 06:56 PM   #51
Ryan_25
My measurements came up the same all around. But if your calibrated eye says its cocked, then what do I know.
bluedogjeep.com
Old 11-01-2008, 11:41 PM   #52
fedrusion
Guys try looking a little closer (i.e. Zoom) you will see they are not cocked. If someone really doesnt believe they are and wants to buy me some gear oil we can settle it real easy.
1999 Cherokee 2 Door Sport (To be modified) Mine. http://www.cardomain.com/ride/2814633/1
5.5" Composite lift, Rough Country Control Arm Drop Brackets, 31X10.5X15 Dayton Timberline AT's On Canyons, 31X10.5 Firestone Destination MT's, P.O.R.C. SYE and front CV Drive Shaft, Homemade Short Ram Intake, Locked 8.25. Comming Soon: Stroker.
2000 Grand Cherokee Laredo (To be left alone) Wife's. http://i151.photobucket.com/albums/s127/fedrusion/IMG_0007.jpg
fedrusion is offline   Reply With Quote
Old 02-16-2009, 04:32 PM   #53
JJR00XJ
So how does it perform on and off-road.
If it ain't broke Don't fix it.......
http://www.ThatStereoShopPgh.com
JJR00XJ is offline   Reply With Quote
Old 02-16-2009, 07:06 PM   #54
kstom
I bought one shortly after thay came out with the 29 spline 8.25 unit. The install was cake. Everything went together like it was supposed to. A week after I got mine installed I drove down to Houston from Wichita and back again and the Aussie performed perfectly although a little thuncky around the corners. Every once in a great while it will bang out fairly loudly, usually if I let off the accelerator mid or late turn. So far I've only heard this twice.
I haven't had the opportunity to really put the Aussie through the paces off road yet but, I can tell you it is a great improvement in traction. I have a little, out of the way, testing ground with several short, but steep hills. Previously, I have never, even under the best of conditions, made it up one of those hills without the aid of the front axle. Post Aussie is a completely different story. I've been out there four times recently in both wet and dry conditions and I've driven up every hill in two wheel drive. Like I said, i haven't done anything really spectacular but, the difference in traction is immediately evident.
kstom is offline   Reply With Quote
Glock Forum
