Quantcast aussie anyone - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > aussie anyone
Official Chassis Saver Rust Preventive Truck & Auto UnIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineTJ 5.25" Speaker Adapters - NalinMFG
Old 12-11-2006, 05:19 PM   #1
ACJ112
aussie anyone
anyone use an aussie locker in there Dana 35. tell me good stuff and bad stuff please??
ACJ112 is offline   Reply With Quote
Old 12-11-2006, 05:21 PM   #2
Rodimus
i don't have one but I'm thinking about getting one for my 30. It seems like I have read alot of good things about them.
99' XJ 5.5" TREKS Y-link kit, SYE, 35" Xterrains on AR wheels with 3.75 BS, TREKS Unibody stiffeners, TREKS Rock Rails, 1-Ton OTK Steering,K&N
Rodimus is offline   Reply With Quote
Old 12-11-2006, 05:29 PM   #3
ACJ112
you got that vaccuum actuator d30 right? i have a limited and it dont got that so what should i put in my front end a trutrac er sumthin
Old 12-11-2006, 05:50 PM   #4
xj 98/yj 94
i have an aussie for the front tho not installed yet... i have heard nothing but good things about aussie..
'95 ZJ.... new DD
'98 XJ.... sold
'98 XJ.... Sold...(biggest regret)
'91 YJ.... Was mine,now dad's DD
'94 YJ.... Sold...
'95 ZJ.... Sold, '04 TJ.... Mom's DD.....'97 TJ.... Sold
xj 98/yj 94 is offline   Reply With Quote
Old 12-11-2006, 06:22 PM   #5
xrayjeeper83
I ran a aussie in the front of my old TJ and will run front and rear in my new axles when I get them in. I loved it, on the road it wasnt noticable though it was the front not rear. And there very very easy to intall. The only thing about putting one in the 35 is just how weak the 35 is, if you have anything over 31's it could easly cause the axle to snap due to the added stress.
Andrew
Oh, I just remembered. You're boring. And my legs work.
xrayjeeper83 is offline   Reply With Quote
Old 12-11-2006, 06:55 PM   #6
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
This is kinda hijacking, but I have a brand new D-35 Aussie that I have decided not to install now that I have commited to swapping in the 8.8 rear end. From all I've read, with reasonable sized tires and a light right foot, a locked D-35 can survive. Put big tires on it, or beat on it and it is likely to break a shaft. For the money (I paid $249 to the door) I don't think it can be beat. Aussie's tech support is great. Before making the purchase I called with a question and the owner himself called me back to answer it. If you're interested in buying mine, make me an offer.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline   Reply With Quote
Old 12-11-2006, 07:34 PM   #7
Rodimus
No, I have a HP D30 without the actuator.
Old 12-11-2006, 08:00 PM   #8
QwkTrip
Is "aussie" slang for ARB air locker or is it something different? Who sells them?
QwkTrip is offline   Reply With Quote
Old 12-11-2006, 08:06 PM   #9
xj 98/yj 94
completely different...
'95 ZJ.... new DD
'98 XJ.... sold
'94 YJ.... Sold...
Old 12-11-2006, 08:10 PM   #10
ktmracer419
1997 XJ Cherokee
www.aussielocker.com
practically the same design as a lock-right only cheaper (in most axles) and with a better warranty
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline   Reply With Quote
Old 12-11-2006, 08:29 PM   #11
QwkTrip
I haven't seen an exploded view but from the outside it looks like a Powertrax locker. Is it the same thing?
I had a Powertrax on my '68 El Camino street/drag car. Worked pretty well but every now and then it would make a loud popping noise like it had just exploded. It was as if it got bound up and suddenly released with an explosive noise while going down the freeway. Down side is that it made for aweful handling in corners. Understeer on the throttle and oversteer off the throttle. Completely non-intuitive.
Old 12-11-2006, 11:18 PM   #12
96JXJ
Pretty much the same. I get a loud pop from my No-slip every once in a while. JIM.
96@6 & 92@3
96JXJ is offline   Reply With Quote
Glock Forum
