Definately NO! Spend a couple bucks and get the correct Dexron III. You can get a gallon of it at Walmart for under $10 if you want to be cheap, but do NOT use the ATF 3.
if it is a replacement for dexron/micron II/III then yes. it will say on the bottle if it is. i used mobil 1 when i put my XJ back on the road with 0 problems.
I believe you can use the ATF+III/IV in your transfer case though. So if you have "so much of it" might as well change your xfer case fluid while your at it.:thumbsup:
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
