#16 | ||
![]() Thanks
#17 | |||
And since I have a backup car if it blows my seals I'll just be sure not to wreck the block and then I'll get to rebuild it! It'll be another Jeep learning experience....The link is dead but it sounds legit. For once I can call the PAPE/CAT shop in a good mood! Haha!
'87 XJ Pioneer with 32" KM2s, etc. Last edited by talentjeep; 11-18-2009 at 07:20 PM.. Reason: Oops |
#18 | |
![]() That seems like... a lot... BTW - Valvoline makes a synthetic diesel motor oil too... I use it in my WK. I think it is a 5w40. JW
1998 XJ - built for offroading 2007 WK CRD - DashHawk, for towing the XJ |
#19 |
'87 XJ Pioneer with 32" KM2s, etc. |
#20 | |
JW
#21 | |
No worries. It just sounds like an awesome solvent/degreaser/oil detergent etc. I'd bet soaking bolts in it helps if your run out of PB. Maybe just a gallon would do. Plus I get stubborn grease on my hands a lot. Could you use it as backup clutch or brake fluid in an extreme pinch? And my Neon has an automatic.
#22 |
atf does work good buttt..... a proper hot oil flush works way better
but if youve got atf lyin around! |
#23 | |
Google just gives me industrial hot oil flush and references to car oil flush.
#24 |
At work we do a bilstein engine flush. It has a petroleum based cleaner with ammonia and other things in it.
The flush is in a heated tank. With the engine off you put this thing on the oil filter adapter and another hose to the oil pan. It then pumps the cleaner thru the block via the oil filter add. and it drains thru the drain plug hole. it works quite well. They only thing it if it is really slugged up the reverse flush can actually clog up stuff. If you are really slugged up use the ATF a couple times. It works great i do it on my truck the day before each oil change. |
#25 | |
It is a little to thick for clutch or brakes, you can use it but it can lead to damaging your calipers, just have a bottle of brake cleaner laying around. A lot of people use an ATF/Acetone mix (50/50 IIRC) and works better then PB blaster by a long shot... but can go bad over time so its best to mix a small amount and use it then fix a gallon size worth of it and use it over the next 6 years....
NAXJA Member #2619 1995 Jeep Sport Cherokee 4x4 with an Auto and 4.0L B&M Transmission Cooler and Autometer Tranny Temp Gauge, Ruff Stuff Diff Cover on D30. Taraflex 1.5" BB (rear shackle only), HD Quadratec leaf springs, RE 3.5" front springs, OME Long shocks, JKS Adjustable Track Bar from K.O.R. Daystar Control Arm Bushings, Bushwhacker Flairs, Rhino lining along bottom trim, AGR PS pump with Cooler & Filter. Bored TB, APN Manifold, New Downpipe, Magnaflow High Flow Cat, Flowmaster Super 44. Dual Oil Relocation Kit running two K&N301 size filters, Autometer Digital Cobalt Oil Temp and Oil Pressure Gauge. |
#26 |
That's quite a concoction. Sounds like it would peel your skin off in short order.
#27 |
Thanks for all the tips for Type F. Being a Ford guy, I've got got probably 8+ quarts of it in a tote in the garage.
Jeep mods are NOT a matter of choice. Jeeps demand to be modified. 97 XJ SE - DD/Light Trail Rig - The War Wagon 98 XJ Sport - Spare Parts |
#28 |
We used to do the atf at a dealership I worked at in the early '90's. It's cool to run for a few minutes or drive around for a few hours, but 500 miles, don't do it. It WILL EAT YOU VALVE SEALS!!!!!! Had to replace many old timers seals from them doing this...
New one-2000 XJ sport- Now has 3.5" lift, Hp 30/8.25 w/4.10's, V8 Zj steering Totaled 3/18/10-'99 Black 2 door XJ DD, 3.5+" bastard lift. SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it! Traded for my XJ - '98 ZJ was pretty and built at one time- Hp30, 8.8 and 5" lift and other stuff. |
#29 |
maybe add a 1/2 a quart of ATF to the oil, once you add a whole quart youll be messing around with the weight of the oil.
as far as eating your valve seals to the poster right above me, your the first time iv heard of that so....it doesnt seem to be to common.
WTB: HP Dana 30, Long Island/New York Area detours backbone system for sale |
#30 | |
What would I know, I only worked as an a.s.e. certified mechanic at a dealership for a couple years anyway.... ![]()
