#1 | |
ATF / Detergent? Really?
So I just read this article:
Project XJ Cheap Cherokee - - Jeep at Off-Road.com And it advocates replacing a quart of engine oil with a quart of ATF for 500 miles or so to clean the gunk out of the engine. The site is usually right but is this crazy? It sounds bat**** crazy!
'87 XJ Pioneer with 32" KM2s, etc. |
#2 |
Stormaggedon
Not the first time I've heard it. I've never done it myself. You'd probably get the same effect just by changing your oil and filter after 500 miles. Motor oil contains detergents that trap contaminants. Sludge forms when the contaminate particles exceed the capacity of the detergent. Changing your oil more frequently than recommended will pick up that sludge.
He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself. --Thomas Paine We work together every damn day. --Jon Stewart Any gas can be a knockout gas, when you wrap a steel cylinder around it and beat someone with it. Low Output 4 Cylinder Jeep Club member #188 |
#3 |
Nope - not crazy. Old mechanic's trick.
Use Type F - it's got a higher detergent content (also makes a good ersatz hand cleaner; use the ATF to remove the grease and crud, then common bar soap will remove the ATF.) Also makes a decent air-tool oil, cutting oil, or honing oil, in a pinch.
Kelley's Works in Progress - www.kelleyswip.com KWiP Parts Exchange - www.kelleyswip.com/exchange.html "recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm) "Outback AIDS - Alcohol-Induced Dizzy Spells" |
#4 | |
Another thing you can use it for is in floor jacks. Your can use ATF instead of hydraulic oil in light floor jacks. Just thought I would add to the list. |
#5 |
Formerly Alice Cullen
Remember, gunk helps seal old gaskets. High detergents like atf, seafoam ect, will find leaks for you
![]() But yes it works, wonders. |
#6 | |
Don't go by the saying oil leaks are common in jeeps and should be addressed if you have any. haha |
#7 |
It's the crank sensor!
The "ATF to the oil" trick has been around for a loooonnnnnggggg time. However, I also would contend that an engine with regular oil changes would have no need for this.
99 Cherokee, 4.0 AW4, NP242 Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche Without "data", all you have is an opinion! |
#8 |
JP magazine did an article where they did this to clean out a 4-cyl in a YJ... As someone said earlier they put in ~1 qt and let it idle for ~10-15 mins then did a regular oil change.
JW
1998 XJ - built for offroading 2007 WK CRD - DashHawk, for towing the XJ |
#9 |
or you could do what i do for my cherokees and tjs, and that is just run 10w-30 diesel oil. it has plenty of detergents and recommended for the flat tappets.... i get mine from CAT.
04 "X" tj electric lime green pearl, 4.0 5 speed, rough country 2.5" suspension, 1.25" bl with the 1" mml xenon flat fender flares |
#10 |
10w-30 is not a diesel oil. 15w40 is probably what you are thinking of. 10w30 is too light of a weight oil to ever run in a diesel.
#11 | |
as you can see, Caterpillar makes a 10w-30 diesel engine oil, they also make it in 15w-40. i get it by the 5 gallon bucket. works great on cleaning a motor and keeping it clean!
#12 |
They do indeed make 10W30 for Diesels, as does AmSoil. Interesting.
#13 |
#14 |
Back in the ooold (muscle car) days before smog devices we used to drain oil, fill with diesel, idle about 5 min drain and flush with cheap no name oil and cheap filter,run around town awhile, drain and fill with the "good stuff" change the filter again and run another 5,000 mi. This is not recommened for todays engines.
RB |
#15 |
i get it for $55, that is discounted. i will find out for all interested, i know its available in quarts gallons and 5 gal buckets.
