ARB dana 30 high pinion - JeepForum.com
post #1 of 12 Old 12-04-2009, 11:58 AM Thread Starter
crf450ish
1991 XJ Cherokee
Is there a difference between the dana 30 high pinon and the low pinon? I keep searching through applications for ARB air lockers for my 91' XJ and all i see for the front is Dana 30, not Dana 30 high pinon. So are they the same? And where is the best place to get ARB air lockers online? thanks
JEEP
crf450ish is offline
post #2 of 12 Old 12-04-2009, 12:34 PM
skullver
Tarpitz
1991 XJ Cherokee
no difference, even the stock carriers are the same but they do have the same carrier breaks for gear sets, 3:54 and down, 3:73 and up. As for best place, I have had good luck with gear sets/tools/install kits etc(don't own a ARB) from Complete Offroad:
ARB AIR LOCKER 3.73 AND UP 27 SPLINE (RD100)
but you may want to hit up some supporting vendors on here for pricing.
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #3 of 12 Old 12-05-2009, 10:46 PM Thread Starter
crf450ish
1991 XJ Cherokee
i thought the high pinion was reverse cut from the factory? i need clarification here cause i just talked to a guy at a 4x4 shop and he said all high pinion diffs are reverse cut. and why do some say 3.73 and up & 3.92 and up.....what the hell? I am duely confused on this matter.
JEEP
post #4 of 12 Old 12-05-2009, 11:13 PM
RussoGuitar
1989 XJ Cherokee
The gears are reverse cut, the carrier makes no difference its just the gears. 3.92 and up sounds like a dana 44 carrier break. I believe the d30 carrier breaks are 3.55 and down and 3.73 and up... meaning one carrier is for gears 3.73 and up (numerically) such as 4.56s... and 3.55 and down would be for gears like 3.55's or 3.07's.
RussoGuitar is offline
post #5 of 12 Old 12-06-2009, 01:28 PM Thread Starter
crf450ish
1991 XJ Cherokee
got it! I have the 10bolt DANA 44 rear end out of an 87' XJ in my 91" XJ along with the STOCK high pinion front diff. so a good way to determine DANA 30 from DANA 44 when dealing with parts is to pay attention to the numerical breaks?
JEEP
post #6 of 12 Old 12-08-2009, 02:04 PM Thread Starter
crf450ish
1991 XJ Cherokee
hey does 764 bucks seem sketchy and too low for an ARB air lockers? how do i tell if its a knock off? wont it say? just lookin for feedback
http://www.4wheelerssupply.com/catal...ducts_id/70986
JEEP
post #7 of 12 Old 12-08-2009, 02:06 PM
nostaw22
Looks like an ARB to me... Just like the one I've got.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #8 of 12 Old 12-08-2009, 02:10 PM Thread Starter
crf450ish
1991 XJ Cherokee
ok. and that a good price im guesssing? since 99.9% percent of everyone i talk to says it costs a grand to get setup with ARB air lockers for each diff.
JEEP
post #9 of 12 Old 12-08-2009, 02:13 PM
nostaw22
I haven't priced them out in a while but that doesn't look unreasonable.
Once you add in the cost of other parts (e.g. the compressor/OBA stuff, which isn't included in that kit) you'll be in for at least $1000...
JW
nostaw22 is offline
post #10 of 12 Old 12-08-2009, 02:24 PM Thread Starter
crf450ish
1991 XJ Cherokee
well you dont have to have an ARB compressor right? cant i just go to wally world and get one of those trunk compressors? sure it wont be as reliable as the 350 ARB
JEEP
post #11 of 12 Old 12-08-2009, 02:29 PM
dendrophobe
Look on Northridge4x4, David has great prices over there. As far as the compressor goes, as long as you can get the right pressures to the lines and get it to turn on when you need it, then any will be fine... But the ARB compressor comes with a Contura switch and wiring harness. For only $229 for the heavy duty version at Northridge and IIRC $139 for the regular, just get the ARB one!
2005 TJ Sport, Light Khaki Metallic
RE 3.5" coils, OME shocks, Currie control arms, JKS track bars, JKS 1.25” BL, JKS 1” BMML, 35x12.5x15 Goodyear MT/Rs, American Racing ATX Chamber (Teflon), JB Conversions SS SYE, Tom Woods driveshaft, Savvy Gas Tank Skid, Warn 9.5ti, Viking synthetic winchline w/safety thimble, Metalcloak bumper, Metalcloak steering box skid, Savvy rear bumper, HP30 w/Aussie Locker, Barnett cover, XRF ball joints, Savvy tie rod flip, mini-skids, housing end JJ's, , Currie Steering, OME steering stabiliser, Metalcloak Tube Fenders/rear flares/rocker guards, ORO SwayLOC, Banks Stinger Exhaust, Cobra 75 WX ST with Wilson Silver Load, S-POD, Alpine/MOPAR RB1 Navigation Unit w/MOPAR iPod integration, Superlift Truspeed speedo correction, Lightforce 140 Lance driving lights, OTRATTW switch panel, Tinted UPOL Raptor Liner, Savvy Black Magic brakes, Centric rotors, Superior Evo rear shafts
In the garage: Viking Offroad 350 series Hawse fairlead, ARB compressor, Savvy corner guards, Novak 231 cable shifter, EBC green stuff/Centric rotors (rear), Savvy tub rails, Savvy taillights
dendrophobe is offline
post #12 of 12 Old 12-08-2009, 02:37 PM Thread Starter
crf450ish
1991 XJ Cherokee
alright. and that blue tubing that comes with the kit....has anyone ditched that for something better?
JEEP
Bolt In High Pinion Dana 44 Starboard M XJ Cherokee Technical Forum 67 08-10-2013 05:22 AM
High pinion dana 30 wannabexj XJ Cherokee Technical Forum 13 02-19-2008 09:16 AM
Dana 30 high pinion vs low pinion 00xj54 XJ Cherokee Technical Forum 10 04-05-2006 07:47 AM
Dana 44 is it high pinion? sleddy5 XJ Cherokee Technical Forum 4 02-24-2005 12:29 AM
low pinion vs. high pinion Dana 30 Nevada Lee XJ Cherokee Technical Forum 2 04-11-2003 11:02 PM
