Quantcast ARB bumper install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > ARB bumper install
Old 05-23-2007, 11:29 AM   #1
gorman
ARB bumper install
I recently installed a new ARB bumper on my XJ (great bumper). I have two questions however. There is a vacuum reservoir in the inside of the stock bumper which I believe is for the cruise control and air con controls. Where is a good place to relocate this reservoir to? I would imagine the engine bay, but where in the engine bay? I didn't get any instructions to that effect with my bumper. I guess this would be an issue for everybody that goes for an aftermarket bumper, not just ARB.
The other question I have is that I now want to install spotlights, but would want it to work together with the brights (high beam). Where to I pick up the high beam wire? There seem to be no access to the lights from the engine bay side, do I take out the head lights form the front? Or do I pick up the wires at the switch at the steering column?
Here's a few pics:
2000 Cherokee Country 4.0l, AW4 auto, NP242, RE/OME 6" lift, OME N35L & N36 shocks on raised mounts, JKS Quicker Disconnects, RE SYE, RE CV driveshaft, 33" Maxxis Bighorns, Cragar D window 15x8 with 4" backspacing, ARB bumper, Hella Comet 550's, Warn M8000 winch, GME GX300 29mhz, custom rocksliders, Gearmax Mod 89 rear axle, HP D30 front axle with WJ knuckles, steering and brakes, 4.56 ratios
gorman is offline   Reply With Quote
Old 05-23-2007, 11:34 AM   #2
XJK
The Guru of Nothing
XJK's Avatar
looks good, very nice looking rig
-Kyle
XJK is offline   Reply With Quote
Old 05-23-2007, 11:42 AM   #3
FitchVA
Jeeper 4 Life
FitchVA's Avatar
on my old ARB, there was a tab on the bumper where you can relocate the bottle to. i'm pretty sure that's what the tab is for anyway. it's on the same side as the original location of the canister. but where you're backwards from us it might be flip-flopped
are you wanting to just use the headlight power wire for your signal to the relay? i hope you're not just going to tap into the headlights to fully power your auxiliary lights. the stock wiring can't handle that load. but if you only want it to signal the relay for your aux. lights, there is a main wiring loom connector under the airbox that you can tap into. but again, where our xj's are mirror images, i'm not sure what side it would be on for you
'98 xj sport (trail toy) | specs
'98 xj classic (dd'er) | specs
'89 mj tinker toy | specs
My XJ Page | My Gallery
FitchVA is offline   Reply With Quote
Old 05-23-2007, 12:35 PM   #4
330LICIOUS
love the ARB! get some PIAA's!
2000 XJ Sport Blue
4.56 HP30/8.25 | AA SYE + CV | ORO U-Turn Steering | RE Extreme Duty Track Bar | TNT Long Arms | 5.5" RE/Bilstein 5125 | 33x12.5 BFG M/T | ProComp Alloy | JCR Sliders | Detours Slimline Bumper/Carrier | ARB Bull bar + Warn M8000
330LICIOUS is offline   Reply With Quote
Old 05-23-2007, 02:00 PM   #5
madrabbitt
arb does make a nice looking bumper, even if you dont run a winch.
i wanted one but it was outside of my price range.
as for the lights. If you're sure you want them to be triggered with the high beams (i wouldnt, i'd run a switch inside) then remove the right side bulb so you have access to the socket, probe the socket with a test light when the high beams are switched on so you know which wire is correct, and tap that wire with a small 14 or 16 gauge wire and tap, and run that to the trigger on the aux light relay.
You want to do it on the right side so you can install the relay and wiring harness for the lights as close to the battery as possible to make things easier.
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 05-23-2007, 03:39 PM   #6
gorman
Great to hear - I'll have a look on the inside of the bumper. There are a number of brackets and things that came with it that wasn't used - maybe some of this could be for the reservoir or otherwise it might be for the fitment of a winch. If there's brackets, on the inside it doesn't matter which side it is - I'll just lenghten the pipe if it can't reach as it is.
Yes, I just want to tap into the wiring loom for the signal to the relay. In fact all the wiring has already been done, incl. the relay and a seperate switch. But the problem I have with the seperate switch is that it will be difficult to dim the spot lights in a hurry if another car approaches at night - I'd rather just control everything from the stalk. Thanks for the tip on the wiring loom under the airbox - I'll have a look there - not everything is mirror images, so it might be the right spot to look.
Old 05-23-2007, 03:45 PM   #7
gorman
I like those PIAA's of yours, they look really nice. I'm still not 100% decided whether I should go for round or square spotlights. At first I was going to get KC Daylighters, but they don't fit, so the alternative would be to go for KC Slimlites. I had a look at square Hella Comet 550's which really looked very nice too and they're about half the price of the KC's.
Does anybody perhaps have a nice pic with square spots fitted on an ARB bumper? And round ones for the that matter? Maybe it could help me make up my mind...at the moment I'm leaning towards the square Hella's.
Old 05-23-2007, 03:53 PM   #8
joedsh
Nice looking rig. I really like the ARB bumper. I wanted one before, but like it even better after seeing it from all angles.
[B]2000 XJ Sport[/B]
Bridgstone Dueler Revos 235/70/15, Sensatracs, Quadratec HD Leaf Springs
Otherwise a stocker
[B]2005 KJ Sport[/B]
Stock
joedsh is offline   Reply With Quote
Old 05-23-2007, 03:58 PM   #9
madrabbitt
gorman. read what i said about tapping the harness behind the light.
you have a good point about dimming the lights with the stalk.
its just, up here in the states, most off-road lights cannot be used on paved streets at all, so we mostly use them on trails, therefore it wouldnt matter if its quickly dimmable or not.
Old 05-23-2007, 04:01 PM   #10
madrabbitt
kc slimlights are 100 watt lights.
hella's comet line are 55 watts when sold here in the states, but i know that all of that line, 450, 500, 530 and 550 will support 100 watt bulbs, since they're sold like that in mexico and europe.
I've used a 4 pack of the 530's before. two white driving, 2 amber fog. They are nice lights, even with 55 watts.
I'm running the kc slimlites on my bumper now, and they're really nice off road.
Old 05-23-2007, 04:08 PM   #11
gorman
Thanks Madrabbit, yes that seems easy enough to just tap into the loom behind the light where the plug fits onto the bulb. I was wondering, is it possible to run an additional switch together with the connection to the high beam switch? That way when the switch is in the ON position the spots work with the car's brights and when its OFF the spots don't work at all and I can dimm and bright just the car's OE lights?
Old 05-23-2007, 04:12 PM   #12
madrabbitt
run a very small wire, like 16 or 18 gauge from the LEFT high beam wire (and not the right like i said before) into the cab, put it on a switch input. run an identical wire from the switch output to the relay's trigger input.
when the low beams are on, the aux lights dont work
when the high beams are on, and the switch is OFF, the lights are off.
when the high beams are on, and the switch is ON, the lights are on.
really simple.
hardest parts will be getting the two wires past the firewall, and mounting the switch.
Old 05-23-2007, 04:14 PM   #13
gorman
You're not making it any easier to choose!!
Yes, the Hella's here also use the 55 watt, while I think the KC Slimlites that I can get have 130 watt bulbs.
Here's two pics I found with square spots. I quite like the IPFs, although I'm not sure if they're a bit big, maybe. The trimmed one with the Hella's again are a bit small, but the 550's are bigger, I think.
Old 05-23-2007, 04:19 PM   #14
gorman
really simple.
Perfect!! Thanks for the tip - I was wondering how the combination of the two switches would be wired. Sounds real simple...
Old 05-23-2007, 04:47 PM   #15
madrabbitt
second picture has hella 530's.
slightly longer, but slightly shorter then 550's.
you can tell because the 530's have side mounted "claws" that hold the reflector/lens assembly in place
kc slimlights are orderable in 55, 100 or 130.
heres my slimlights:
Glock Forum
