#1 | |
The Post man
April Cherokees of the Month
The winners for April are -
Stocker Class: XJ99 (click here to see the voting) Modified Class: james harmon (click here to see the voting) Congratulations guys! And nice "come from behind" win James. Winner of the Stocker Class XJ99 1999 XJ Classic (Stone White) 4.0L, Auto, NP231 Transfer Case Rusty's Front Tow Hooks w/brackets (4) 55 watt lights mounted on roof rack 400 watt power inverter Custom 12-volt plug in hatch Cobra CB with LiL WiL magnet mount antenna w/PA Custom placed Clarion 75X75 amp in rear wheel well ![]() Class III rear tow hitch (also serves as recovery point) Good Year Wrangler A/T's 235/75/15 Chrysler 8.25 rear 29 Spline axles Front Dana M30/181MM Axle Ratio 3.55's Full Power, tilt wheel, factory tint, cruise (ya) On board items include: (always in Jeep) Bow saw, Fire extinguisher, tow strap, 12-volt emergency tire pump, tire plug kit, (2) FRS radios, 100ft extension cord, hand held CB, Maglite, U-joints, Jumper Cables, basic tools, gloves, and tie downs. ![]() Winner of the Modified Class james harmon .....1990 Cherokee Larado .....4.0 lt. AW-4 tranny, 231 X-fer case .....Purchased in1992 & here we are12 years later.............. .....Over 200K miles & running strong .....First lift was Trail Master 4" drop down bracket kit & ran 31" tires .....Second lift was a Tomken 4" lift & ran 32" tires .....Presently the lift is a mix-match of Clayton and the two lifts mentioned above along with some other stuff, running 35" tires Suspension .....Clayton Long Arms .....Trail Master 4" coils, sagged to 3" with 2" spacer & 1 factory isolator ,,,,,Tomkin 4" rear spring pack, sagged to 2.5" with 1.5" lift blocks .....Load leaf flipped upside down in spring pack .....Greaseable bolts in shackles and spring pack .....Revolver shackles mounted to modified hangers for shackles to clear .....Front shocks: Rancho RS9017 front wih 2" extensions bottom, 1" on top .....Rear shocks: Rancho RXS9012 mounted on Cross Enterprises shock hoop .....Sway bars removed front & rear .....Daystar extended urethane bump stops mounted on Tomkin extenders Drive Train .....Dana 30 in the front converted to non-disconnect, 4:10 gears, ARB, Superior chrome-moly axles, Drivetrain Direct axle tube seals .....Dana 44 high pinion in the rear, 4:10 gears, ARB, & angled spring perches, cutom built for me, by Tri-County Gear .....Custom drive shafts front & rear Wheels & Tires .....GoodYear MTR's 315 75 16" (35X12.50) .....MT OutLaws II 16X8" 4.5" backspacing .....Matching spare mounted on the rear Heavy Metal .....Ramsey Bumper, reinforced to frame with 3/16" 1.5" square tubing .....Smitty Built brush guard modified to fit Ramsey bumper .....Warn XD9000 winch .....Custom 4X4 rear bumper with spare tire & Hi-Lift jack mount ,,,,,Rocky Road Outfitters Rock Rails .....HomeBoy X-fer case skid plate .....HomeBoy gas tank skid plate .....FourXDoctor diff guards Engine & Tranny .....Borla header .....2.25" cat back with Flow Master .....6" X 9" K&N air filter .....Tornado air management system .....Accurate Power throttle body 5mm larger than stock .....Directhits Ignition system .....Excel 8mm wires .....Compu Shift Plus transmission computer .....Cooling system converted to "open" .....96 "curved" blade aux. fan .....Air conditioner converted to R-134a Brakes & Steering .....WJ front knuckles, rotors, calipers, tie rods & linkage .....ZJ rear disk brakes .....Wilwood adjustable proportional valve ,,,,,Extended stainless steel brake lines all the way around .....Rancho steering stablizer .....Rusty's steering box brace .....Rusty's extended & adjustable track bar .....Reinforced track bar frame bracket with 1/4" plate Electrical .....Dual batteries: Optima Red top & Hawker Genesis XE .....2 and 4 gauge cables for batterys, fuse block and alternator .....IPF head light inserts and H4 Magic J-bulbs .....Hella 500 Fog lamps .....Hella 500 Fog lamp for back-up .....Hella 500 running lights ....."Pimp Daddy" carbon fiber looking tail lights .....Front clear corner lights .....4X4-Mods white glow gauges .....FIAMM horns .....Kenwood deck & amps. Bazooka sub, 2 sets of Infinity 5.25" tweeter seperates .....Megellan Meridian GPS .....Midland CB & Little Wheel antenna Mics. .....Bushwacker cut-out fender flares .....Class III reciever .....ARB compressor rigged for tire inflation .....Tinted windows .....Lido wheel well storge .....Husky floor liners .....HomeBoy raised console and storage .....Aluminum petals .....Aluminum dash overlay .....Rubber shorty antenna .....12V outlet in the rear Here are the rules for entering the Cherokee of the Month for anyone that would like to participate in the May COM. Here are the previous months: January February March
#2 |
Thanks
I’m pretty sure this does not mean I have the most desirable or the most capable rig this month. What this does mean is this, I have a lot of really “Good Friends” and that is something I'm very proud of!!!!
James http://geocities.com/jammerjamesharmon/
90 Larado, 5" lift, 35" MTR's, HP/D44/ARB/488, D30/Superior axles/ARB/488, Clayton Long Arms, Revolver shackles, WJ front brakes, knuckles. linkage & master cylinder/booster, ZJ rear disk brakes, Warn XD9000, etc, etc, etc........ Last edited by james harmon; 04-01-2004 at 07:24 AM.. |
#3 |
Broke Bogger
Good Job James (my nomanie hehe, well i think anyway)
Matt __________________ 97 XJ - Black Sport, 4.0L AW4, D30 and 8.25 6" Skyjacker/RE, 33x13.5 Swamper LTB Cracked Frame, good for steering!!! MY XJ PICS |
#4 | |
K I S W
You took the words out of my mouth..... Like everyone else pointed out I think I had some really good wheelin pics in the XJ wheeling pics Thread that helped a lot... Once again thank you Ken..
When we do right, no one remembers. When we do wrong, no one forgets. |
#5 |
Congrats guys! I'll try again next month ....I just ordered a few things...top secret though. Nothing crazy though, I'll still be in stocker class. You'll see next month. MUWAHHHHAHHAHA... ![]()
[URL=http://www.jeepforum.com/forum/showpost.php?p=495486&postcount=181][COLOR=BLUE]MY XJ PICS[/COLOR][/URL] 2000 XJ Sport 4.0L, NP231 3" Old Man Emu Lift 30"x9.50x15's BFG KO's Quick Disco's "The Wallmart Lightbar" |
#6 |
Great job guys. Really diggin your rig 99'. Well the mud and your rig....
[/drool]
[SIZE=1]1995 Jeep Cherokee Country AW4, NP231, 4.0L I6 7.5" lift, 35's, 8.8 out back, 4.56's, etc.[/SIZE] [URL=http://www.amt.org/scott]My Cherokee Website[/URL] [URL=http://www.missionrepublic.com]My Clothing Company[/URL] |
#7 |
Congrats on the win guys!
Nice looking rigs. Rock On! Steve
[CENTER][SIZE=3][URL=http://www.fm2cd.com][COLOR=darkred]Follow Me To Certain Death 4x4 Club VA Chapter Founder[/COLOR] [/URL][/SIZE] [size=3][url=http://jeephorizons.com][COLOR=sienna][b]Jeep Horizons - Where Avatars are always free[/COLOR][/b][/url][/size] [B][size=3][url=http://www.links4jeeps.com/in.php?id=893/]Links 4 Jeeps - Yup, they're free here too[/url][/size][/B] [URL=http://www.fm2cd.com/chapters/VA_Chapter/VA_Members.htm#cname] 97 XJ Sport 2 door with a bunch of stuff[/URL] [url=http://www.fm2cd.com/chapters/VA%20Chapter/VA%20Members.htm#dname] 02 TJ Sport with a bunch of stuff[/url][/center] |
#8 |
Congrats guys. Nice Rigs!
keep up the good work.
The meaning to life is to live, So Go Live....Offroad :o) [COLOR=red]******************************************[/COLOR] [B][U]1998 Cherokee, 2 Door, Black.[/U] [/B] 4.0 L Power Plant, NP231 Transfer Case 32" BFG All Terrain Tires on 15"x7" "Grizzy" Jeep wheels Helix TB Spacer with K&N Replacement filter. C4x4 Rear Bumper/Tire Carrier with hitch and towhooks :) DPG Rock Attack XJ Gas Tank Skid Plates RE 4.5" lift - With 1" 5/8 Spacer up front, and 1" Spacer and 3/8 shim in back. So over 6" of lift. |
#9 |
I was looking at "James Harmon's" second picture......am I seeing things or is the coil spring actually a couple inches off of the spring seat?
#10 |
spring unseated
That is what you are seeing. This is fairly common with big articulation. Usually you are going at a slow speed when this happens, so there is no damage with it banging around. As long as the spring does not come out of the top “perch/bump stop extension” whats the harm????
James www.geocities.com/jammerjamesharmon
90 Larado, 5" lift, 35" MTR's, HP/D44/ARB/488, D30/Superior axles/ARB/488, Clayton Long Arms, Revolver shackles, WJ front brakes, knuckles. linkage & master cylinder/booster, ZJ rear disk brakes, Warn XD9000, etc, etc, etc........ |
#11 |
Broke Bogger
Yeah I saw that too. I had to do a double take cause at first it looked like you had spacers in there, and them I was oh no, its are off the top. I was watching one of those 4 wheelin videos from out west and the was a guy flexing past the bumpstops and another guy was holding the spring as he was coming back down to make sure it seated properly.
How'd you like that job, haha.
#12 |
Congrats to the winners and thanks to all those that voted for me.
I'm going to sit out of the next several votes since I already had my chance and also to make room for new nominees.
[FONT=Trebuchet MS][size=1]97XJ RENEGADE |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
