anyone running load range E tires? - JeepForum.com
post #1 of 7 Old 03-02-2009, 11:10 PM Thread Starter
Muddeprived
Muddeprived's Avatar
I came across a deal for four nearly new mtz's for $500 but they are E range tires. Are these not a good tire for lightweight cherokees or will i be alright with em? I don't want a stiff-as$ ride.
Chris
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #2 of 7 Old 03-02-2009, 11:16 PM
83iS
I would venture to say that you'll be fine, I had a set of Load Range D's on my 99 I just ran them at a lower pressure, granted the ride would rattle your teeth out at times and it would get a little twitchy on some rougher back roads but if you use a little caution and all I think you would be ok. But thats just me
Kyle
1999 XJ Limited.... R.I.P 10/27/06
1998 XJ Classic, stock for now.
83iS is offline
post #3 of 7 Old 03-03-2009, 05:52 AM
lurkeryj
1997 XJ Cherokee
i wouldnt. its way too much tire for a cherokee. the added weight will kill your acceleration and you'll have to run at least 55psi in a load E in order for them to wear correctly. i vote no
lurkeryj is offline
post #4 of 7 Old 03-03-2009, 08:00 AM
Krazors001
2014 JK Wrangler
I'm running them on mine and don't think they are that bad. I am running around 32 PSI I think and the wear is fine. I think it is a little rougher than when I had my other tires but I think that is also do to going from BFG ATs to Cooper STTs. Who knows though, it may have been worse had I not installed the supple OME suspension!-)
Current: 2014 Wrangler Sahara
Sold: 2001 Jeep Cherokee Sport
Krazors001 is offline
post #5 of 7 Old 03-03-2009, 08:14 AM
lurkeryj
1997 XJ Cherokee
32psi in a load range E is no good. just my .02
lurkeryj is offline
post #6 of 7 Old 03-03-2009, 09:01 AM Thread Starter
Muddeprived
why?
post #7 of 7 Old 03-03-2009, 09:33 AM
XJohnnyC
XJohnnyC's Avatar
I'm running E load rated 305/70/16 Maxxis Bighorns on my XJ and the road ride is very smooth. The main reason I went to an E load rated tire was for the beefier sidewall. I had some 33x12.50x15 C load rated MTRs that had some thin-*** sidewalls and I blew one driving down the highway.
I've driven my Jeep to the Rubicon and to Moab on the Bighorns. Very nice ride. And I've not noticed any decrease in gas mileage. I run 32 psi on the highway and they are wearing perfectly smoothly.
On my MJ, I'm running the E load rated 245/75/16 MTRs that came stock on the Wrangler Rubicons. Again, no issues.
XJohnnyC is offline
Running with different sized tires firebear XJ Cherokee Technical Forum 15 09-21-2007 02:14 PM
Running / Under load fuel pressure BackDraft XJ Cherokee Technical Forum 2 08-14-2007 05:05 PM
Load Range D too much? SkyHigHXJ XJ Cherokee Technical Forum 9 07-18-2007 10:28 PM
is anyone running a D class (load rating) tire on their wheeled XJ? BigOrangeXJ XJ Cherokee Technical Forum 7 08-29-2006 04:19 AM
Which Tires Are You Running? (POLL!) 01JeepXJ XJ Cherokee Technical Forum 48 03-22-2005 10:22 PM
