Anyone have a writeup for removing the TC? - JeepForum.com
post #1 of 3 Old 11-02-2007, 05:23 PM Thread Starter
jeepfever87
1987 YJ Wrangler
I'm getting ready to pull my TC and basically have no idea what i'm doing. Anyone have any tips?
1999 XJ Sport- 4.0, AW4, np231 w/ Tera SYE, Rusty's 4.5", 33x12.5 tsl's
1987 Wrangler- SOA, 44 front, 9 inch rear, mustang 5.0, 38x13 swampers
1993 grand- 5.2, auto, IRO 3.5" on 32 bfg muds
Originally Posted by Cherokeegrrl
What's the point in having adjustable headrests if ya strap them down? (It's like a girl doing that to her um ... dubble_D's. )
jeepfever87 is offline
post #2 of 3 Old 11-02-2007, 06:10 PM
98FleXJ
i dont have a write up but i can tell you step by step what you need to do..
okay first you need to undo the linkages to the 4wd, take off front and rear driveshafts, and the three connectors on the t-case its self, after you have all of that done remove the four bolts in the middle of the t-case cross member then jack up the transmission pan with a jack and a block of wood (to distribute the weight evenly), un bolt the tc skid and put aside for later re install. okay now unbolt the trans mount and now your going to want to drop down the t-case by lowering the jack(so you have more room to get a wrench in up there on the top bolts of the t-case Hint Shorty ratchet wrenches are great for this task. un bolt the 6 bolts on the t-case and slide it off. its not heavy weights about 70 pounds, oh yeah i almost forgot drain the fluild out before doing all of the above. then to reinstall just do everything in reverse.
98FleXJ is offline
post #3 of 3 Old 11-02-2007, 06:33 PM
Paul_C
http://mallcrawlin.com/forum/showthread.php?t=8549
Oops, not a full removal, but it will get you close.
Paul_C is offline
Hercuiner writeup jeepkid8037 XJ Cherokee Technical Forum 15 12-05-2009 06:16 PM
Doing a writeup? SILASPRIT XJ/MJ Cherokee Non-Technical Forum 6 01-06-2009 01:00 PM
Thorough Manifold Writeup StokedXJ11 XJ Cherokee Technical Forum 1 04-17-2007 09:40 PM
A/C Tech Writeup? Answerguy7 XJ Cherokee Technical Forum 4 05-29-2005 09:25 PM
Anyone interested in writeup? kingfish XJ Cherokee Technical Forum 4 06-03-2003 04:18 PM
