Anybody with Rusty 4.5 150 lb coils - JeepForum.com
post #1 of 3 Old 02-06-2010, 01:12 PM Thread Starter
Highway 4x4
Anybody here useing the Rusty 4.5 150 pound springs? Any good? Soft ride? How much actual lift? These are about the softest rated springs I have seen and are cheeper and easier than drop brackets to get a softer ride with lift.
Highway 4x4 is offline
post #2 of 3 Old 02-06-2010, 01:56 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Those coils ride nice and flex well when paired with a good set of shocks, but 4.5" on shortarms is gonna ride stiff no matter what coils and shocks you use. I don't know if the softer coils will benefit you enough to make them worthwhile. If you are running the RE coils that are in your profile it is likely that you won't see any improvement. I would look into a set of drop brackets or the RC longarm upgrade. Either of those will give you a huge improvement.
xjfever is offline
post #3 of 3 Old 02-06-2010, 02:04 PM Thread Starter
Highway 4x4
I have the RE 4.5 170 pound coils, get about 5.5 in lift, JKS adj lowers, OME nitro charger shocks, all good but stiff. Probably like you said about the short arms and lift. Thinking of adj uppers to position the ft axel back out where it belongs, just don't want to rub when tire is flexed up into fender.
Coils? or coils and spacer? djlarroc XJ Cherokee Technical Forum 9 10-28-2009 08:47 AM
4.5 Coils w/ 1.5 spacers or 6.5 coils out right? xxxjxxxj XJ Cherokee Technical Forum 9 02-15-2008 06:29 PM
OME coils vs Rusty's coils alexrule123 XJ Cherokee Technical Forum 26 05-17-2007 10:18 AM
Rustys 6.5" coils spring rate vs. RE 5.5" coils jeeponly XJ Cherokee Technical Forum 2 12-14-2004 12:43 AM
rusty vs ome billbarr100 XJ Cherokee Technical Forum 2 04-20-2004 06:52 AM
