Any tricks to installing lift shackles? - JeepForum.com
post #1 of 8 Old 01-13-2010, 07:39 PM Thread Starter
Kevin108
I got a set of RC 2" shackles I'm going to put on Friday. Any tips?
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #2 of 8 Old 01-13-2010, 08:06 PM
jimbosz07
PB BLASTER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Otherwise no
jimbosz07 is offline
post #3 of 8 Old 01-13-2010, 08:07 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Tips as in what?
You remove the stock shackles, put the new ones in, and torque the bolts.
Do you need a step by step direction as to how to change the shackles?
You kind of confused me....
Are they 2" lift shackles, or 2" longer than a stock shackle, meaning 1' lift? If they are 2" lift shackles, be prepared for a goofy pinion angle, possible vibrations, and your leaf springs not lasting too long.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #4 of 8 Old 01-13-2010, 08:30 PM
RockRodHooligan
RockRodHooligan's Avatar
It helps to have a lot of PB and access to air tools.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #5 of 8 Old 01-14-2010, 05:42 AM Thread Starter
Kevin108
I swear by PB Blaster at home and at work, so that's a given.
LLT: Jeep XJ Adjustable Shackles My springs have a slight negative arch. I'm sagged 1.75" on the drivers side and 1.5" on the passenger side. This was a quick fix until I feel like fooling with the spring packs.
HH: I have access to air and impact wrenches, etc.
Kevin108 is offline
post #6 of 8 Old 01-14-2010, 11:12 AM
Moose_God
Moose_God's Avatar
1994 XJ Cherokee
You will need:
Air tools and/or a long breaker bar and cheater pipe.
Prybar for getting everything aligned.
Beer.
94 Cherokee Sport 4wd (converted from 2wd), AW4, NP231 w/SYE, 6" bastard lift, RC drop brackets, IRO trackbar, 33x12.5 Goodyear MTRs, HDoffroad subframe connectors, prerunner front bumper, homebrew rear bumper, flowmaster 40, 96 booster swap., upgraded headlight harness, 4.56 gears (finally!!!)
Moose_God is offline
post #7 of 8 Old 01-14-2010, 11:19 AM
XJH-007
XJH-007's Avatar
Beer.
X2 especially the beer
TIP:
Don't torque your shackle and leaf bolts down until the weight of the vehicle is back on the suspension. I've had issues with the shackles not seating correctly when torqued in the installation position (drooped suspension)
Also, every xj I have worked on had the nuts on the outside (near fenders) so to get the bolt out you had to loosen exhaust, and even skid plates (if equip) When reinstalling, put the nut on the inside.
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #8 of 8 Old 01-15-2010, 10:01 PM Thread Starter
Kevin108
What I learned today:
Rough Country includes no instructions at all - just a box full of shackles, hardware and other pieces you won't understand until you remove the factory shackle.
It takes longer to get the jack stands setup optimally than it does to actually install the shackles.
Have a friend handy. It was infinitely easier to have someone else pry on the springs while you lined up the shackles just so to insert the bolts.
If you have a Curt rear hitch, you can't put the bolt in on the drivers' side with the nut on the outside. This results in the nut making contact with the tail pipe and rattling occasionally. The bolt head is thinner than the nylock nut and would likely clear the tail pipe but the hitch blocks you from being able to insert the bolt the opposite way.
My solution was to cut the factory pipe just behind the last hanger and replace it with a bolt-on turn down from the parts store. The new turn down tapers down in front of the shackle instead of behind it.
Kevin108 is offline
installing rough country shackles tomorrow kboyts XJ Cherokee Technical Forum 1 07-06-2009 03:50 PM
installing new rear shackles tahoevicxj XJ Cherokee Technical Forum 1 09-17-2008 02:56 PM
do I need to modify my exhaust when installing longer shackles? rosader XJ Cherokee Technical Forum 11 11-28-2006 11:51 AM
Installing Lift Shackles! MendoXJ XJ Cherokee Technical Forum 3 07-17-2003 04:46 AM
