Any pics of a stock xj and 30's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Any pics of a stock xj and 30's?
ORS Recovery RopeSynthetic Winch Rope from ORSFree shipping on Rugged Ridge XHD bumpers
Unread 03-26-2002, 08:34 PM   #1
glennv
Anyone have a pic of a stock xj with 30's? (no lift, stock wheels.)
Thanks
2002 Sport: I6, 4.56 gears, SYE, RE 3.5", 305 BFF MTs.5-spd,d30/d44.
2004 Grand: I6, wife's
1998 XJ: My daily driver. I6
"The Second Amendment is not about duck hunting, and I know I'm not going to make very many friends saying this, but it's about our right, all of our right to be able to protect ourselves from all of you guys up there." - Dr. Suzanna Gratia Hupp, appearing before Representative Charles Schumer's committee hearings on the assault weapons ban
glennv is offline   Reply With Quote Quick reply to this message
Unread 03-26-2002, 09:34 PM   #2
joeldavid
My stock (mostly) xj has 30 inch tires. Take a look at <a href="http://www.azvjc.org/" target="_blank">http://www.azvjc.org/</a> go to members or gallery and look up my name Joel Molenaar. My xj is not lifted and doesn't have the up country option. I do have diconnects. The tires only rub when disconnected and fully flexed.
Hope this helps,
Joel M
joeldavid is offline   Reply With Quote Quick reply to this message
Unread 03-27-2002, 12:08 PM   #3
silver2000XJ
this is just to reply to david. 235/70R16 are 29" tires not 30". 30's will rub on 97 and newer on full turn and if u hit a hard bump offroad u could rip ur inner fender out. 235/75/15 will fit safely. thats the biggest unless u do a budget boost or hack ur fenders. happy motoin
silver2000XJ is offline   Reply With Quote Quick reply to this message
Unread 03-27-2002, 06:28 PM   #4
joeldavid
Actually the bfg at 30x9.5 is 29.4x9.4 while the 235 70 r16 is 29.1x9.5, 3 tenths of an inch smaller in diamater 1 tenth wider. The 235 75 r16 is 29x 9.1 this is true for most tire manufactures, at least bfg and goodyear. Will that 7/16 of an inch or so make a differance, maybe. My jeep is not lifted and is not an upcountry I don't rub at full lock I do rub when disconnected and fully stuffed into the wheel well. The tire can still turn and is not tearing any thing up, where they rub is in the middle of the wheel well and a tiny bit on the flare. If you are not disconnected I would imagine that either size would fit with no rubbing at all. If you are disconnected that 7/16 could make a differance, but I don't know how much. It Doesn't matter much to me any more because I came across <img border="0" title="" alt="[Wink]" src="wink.gif" /> some coil spacers and shackles that will be alleviating the little bit of rubbing I have.
I hope this helps and doesn't cause confusion,
Joel M
Unread 03-27-2002, 06:57 PM   #5
glennv
So I have a 93 sport and plan to put a set of Goodyear GSA tires on it. The actually measure 29.5 x 9.5. Any thoughts?
Unread 03-27-2002, 07:01 PM   #6
joeldavid
I think if you aren't disconnected they won't rub. If you are disconnected and the rub too much a budget lift or a 1/2 inch added to you bump stops will stop it.
My .02,
Joel M
Unread 03-27-2002, 07:43 PM   #7
BLK2000XJ
Here is a picture of a stock Cherokee with 30s. We have since lifted it and put on 31s. <a href="http://community.webshots.com/album/33852220iiteuY" target="_blank">Jeep w/30s</a>
Black, 2000 XJ, Rusty's 3" lift, Heavy Duty SYE, Flowmaster exhaust & 31x10.50-15 BF Goodrich Mud Terrain KM's. So far...........
2003 Liberty Limited, 255/70-16 Goodyear Wrangler MTRs [url]http://community.webshots.com/user/marypax
[/url]
BLK2000XJ is offline   Reply With Quote Quick reply to this message
