Any difference in hubs...? - Page 3 - JeepForum.com
 2Likes
post #31 of 58 Old 05-04-2013, 05:22 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If your replacement brake parts are good quality parts, there is no difference in braking performance or brake service life, cast vs. composite. Cheap parts vs. good quality parts, good quality parts always last longer and perform better.
CJ7-Tim is offline
post #32 of 58 Old 05-04-2013, 08:05 AM
Uziel
and for the bearing themselves, newer = better ?
Uziel is offline
post #33 of 58 Old 05-04-2013, 08:14 AM
CJ7-Tim
CJ7-Tim's Avatar
No differences in hub type either. Cheap parts vs. good quality parts, good quality parts always last longer and perform better. I always buy Timken brand hubs.
CJ7-Tim is offline
post #34 of 58 Old 05-04-2013, 08:17 AM
Uziel
okay thank you
Uziel is offline
post #35 of 58 Old 05-23-2013, 02:27 PM
xjpower1
Originally Posted by CJ7-Tim View Post
[SIZE=2]1999.5 to 2001 unit bearing/hub on the RIGHT of the picture uses the CAST ROTOR. The 1999.5 - 2001 unit bearing/hubs have the taller ring around the 36MM shaft retaining nut. It is 1-1/8 inch tall and the hub has longer lug nut studs than older hubs. See pictures below.
1990 to 1999.5 unit bearing/hub on the LEFT of the picture uses the COMPOSITE ROTOR. The 1990 - 1999.5 unit bearing/hubs have the ring around 36MM shaft retaining nut that is approximately 3/4 inch tall. See pictures below.
I am going to add my experience on this subject to this. I replaced a unit bearing today, after looking at both timken units in the store, I went with the cast rotor bearing. Interesting though, the ring that goes around the 36mm nut is 3/4 inch tall as was the size of the skirt on the old unit bearing.
I would say it's possible that timken at some point used the same plate (or whatever you want to call it) on both styles of unit bearings.
I think it would be really helpful to add what the overall height of each bearing is as there is a clear difference between the 2.
xjpower1 is offline
post #36 of 58 Old 08-04-2013, 11:56 AM
TippyJeep
Doing the front brakes on my 99 XJ for the first time since I bought it in Dec 2009. I did the passenger side first and everything went fine (rotors calipers and pads). Driver's side didn't go so well. After a lot of work and four letter words, I realized I have two different hubs. Passenger side has the longer studs and higher retaining nut ring. Driver's side has the shorter studs and the shorter retaining nut ring. I was able to get the driver side caliper on (not easily though) and I don't have a lot of threads left on the stud for the lug nuts but I think I'm OK (I've been driving it this way (unknowingly) for almost 4 years and never had a problem) so my question is this:
1. should I leave the driver's side hub in and buy a composite rotor to fit the hub
2. should I buy a hub to fit the cast rotor
3. Can I leave it as is (cast rotor on the composite stye hub)? Again, this is the way it was when I bought it and have had no problems with it.
The build date is Jan 99 so I'm not sure what was on there originally. The passenger side hub (cast rotor) looks a little newer.
What am I looking at if want to swap out the hub? Is there a wheel bearing in there that I need to deal with or is it just a matter of removing the cotter pin and retaining nut and putting on the new hub?
TippyJeep is offline
post #37 of 58 Old 08-04-2013, 03:15 PM
CJ7-Tim
CJ7-Tim's Avatar
1) If you need a new rotor, buy whatever rotor fits the hub in question. If you need longer lug nut studs, the auto parts store can order some.
2) Rotors are cheaper to buy, and easier to install than hubs, if the hub is OK, you can leave it alone. If you need one new hub, I would buy the same type as on the opposite side.
3) There is no technical or safety reason that says you cannot have one each of the different hub types on the same axle, but it might make buying new brakes in the future a bit more complicated.
There are plenty of hub install threads and YouTube videos. The basic steps are remove the hub and axle shaft from the axle housing, remove the 36mm axle nut, separate the axle shaft from the unit hub, assemble your new hub onto the axle shaft, and reinstall everything onto the axle housing.
CJ7-Tim is offline
post #38 of 58 Old 12-16-2013, 03:21 PM
02grandy
my 99 jeep xj manuu date 6/99 ..........ok here is my problem......... when I got this two years ago I did calipers pads and rotors. the local parts guys told me there were two different rotors. so I went by their word.. I think I even brought the rotor back and tried it on but it didn't work thats why I went back. but everything seems to work fine. now after looking at the parts ... I clearly have the cast iron rotor from the measurements and the pictures but my wheel hubs measure the 3/4" measurement like the composite wheel hub should but the picture is looks like the cast iron /99 and up because of the space between where the flange for the 3 bolts go and the 5 bolt flange for the rotor is complete smooth metal. it doesn't look like that gab with that black rubberish stuff
02grandy is offline
post #39 of 58 Old 12-17-2013, 11:56 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
As long as your brakes work properly and don't constantly drag then id bet you have the correct hub/rotor combo. As long as you keep those both consistent you'll be fine.
1990JEEPXJ is offline
post #40 of 58 Old 02-25-2014, 04:50 AM
feipoa
I too have the cast rotors. The replacement hubs I ordered 2 years ago for cast rotors also had the 3/4" tall ring on the hub. The rotors, which are still original from my '99 XJ purchase, seem to fit and work fine with these hubs. A few people in this thread have mentioned this now. I wonder if you should add a caveat to your original post?
I bought my XJ new in 1999. It has a build date of Dec. 1998. I am still using the original rotors, but I have new hubs and calipers. My cast rotors agree with your measurements for cast rotors. I am posting now because I'm in the market for some new rotors and brake pads.
feipoa is offline
post #41 of 58 Old 04-23-2014, 12:29 AM
Moneypitjeep99
Ok don't want to bring up old stuff but I am chasing a popping and pulling situation and yes alignment, ball joints, bushings, track bar, axel u-joints, are done as well as adjusting and going through upper and lower control arms, I was reading this article and checking my front wheel bearings and realized my rotors were wrong for my hubs as for the dimensions listed. So I went out and bought correct fitment ones and after tightening lug nuts the wheels do not turn.
Before I set it on the ground and take her for a run and chock up the $80 loss on rotors as I've already done and can't take these back does anyone have any advice? I checked and rechecked all my measurements on my existing rotors and ones at the auto parts store prior to buying. My old ones were less than month old and worked but my main concern is chasing an grinding popping noise up front at slow speeds 5-10 mph especially when going up a hill and it has become progressively worse and noticeable at higher speeds.
Moneypitjeep99 is offline
post #42 of 58 Old 04-23-2014, 01:42 AM
Moneypitjeep99
I have seen the measurements mixed up on several jeep forums now between which gets composit rotor or cast as to the height of the ring around the nut on the hub. 1-1/8, 1/2, 3/4. 3/4 or 1/2 is cast?
post #43 of 58 Old 04-23-2014, 11:22 AM
CJ7-Tim
CJ7-Tim's Avatar
There are only two Chrysler type hubs, as shown in the pictures of Post #2 above. The early 99 and older hubs have a ring measuring about 1/2" and the late 99 and later hubs have a ring measuring about 3/4". A size difference of greater than 1/4 inch should be easy to differentiate with a ruler or tape measure.
Nearly all factory installed composite construction rotors have been replaced with auto parts store replacement rotors made from cast iron blanks that are machined to have have measurements similar to composite rotor parts. Do not simply look at your rotors and assume you have a certain rotor type, you need to measure them.
If you install the wrong rotor type/dimensions for the hub type on the axle, the brakes will bind up severely when you install the rims.
CJ7-Tim is offline
post #44 of 58 Old 09-02-2014, 02:50 PM
motherpuncher
Ok, I need new hubs and rotors on my 99. So am I understanding correctly, that as long as I order the same set together it doesn't matter which I order, they will work? And the calipers are going to fit regardless of which set I choose?
Thanks
motherpuncher is offline
post #45 of 58 Old 09-02-2014, 04:40 PM
CJ7-Tim
CJ7-Tim's Avatar
So you don't confuse the auto parts counter guy, just order hubs and rotors for a 1998, or for a 2000. 1990 - 2001 Calipers will work with both.
Crankshaft46 likes this.
CJ7-Tim is offline
1999 , brake rotor , cast rotor , composite rotor , d30 , dana 30 , high pinion , low pinion , unit bearing , unit hubs
Which one is right? HUBS BIG_J XJ Cherokee Technical Forum 9 01-10-2009 08:28 AM
New front Hubs......what a difference mfinkler XJ Cherokee Technical Forum 7 05-20-2008 12:11 AM
D30 with hubs? Tom Gralewski XJ Cherokee Technical Forum 6 11-06-2006 08:03 PM
Hubs - are all d30 hubs created equally? Interchangeable? OH-ZJ-IO XJ Cherokee Technical Forum 2 09-07-2006 08:35 PM
New Hubs Trickytim444 MJ Comanche Technical Forum 5 02-01-2006 09:51 AM
