Quantcast Any difference in hubs...? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Any difference in hubs...?
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 08-08-2008, 08:11 AM   #16
jebmccall
1997 XJ Cherokee
33x12.5, stock limited 6.5 bs. and thats all the money i had for it
jebmccall is offline   Reply With Quote
Old 08-09-2008, 10:28 PM   #17
dopod
I just got done swapping out my hubs/rotors to the pre 89 style with tapered roller bearings on my 96. Works great
dopod is offline   Reply With Quote
Old 08-10-2008, 11:45 AM   #18
Bryson
I'm glad someones finally done this!
Did you notice any changes (even subtle)? The tapered bearing should be much much more stable under torsional loads, which should (in theory) result in a more stable front end and less deflection.
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production - www.CortekSystems.com
Owner of Boostwerks.com
Website in development.
Bryson is offline   Reply With Quote
Old 12-30-2009, 04:34 PM   #19
J_E_E_P_X_J
Originally Posted by Bryson View Post
Can you also judge by the look of the rotor? From the pic it seems like the composite rotor has a rounded edge at the lugs, where as the cast has a typical 90deg angle.
There are two pictures of rotors, the top picture is a composite rotor and the bottom picture is a cast rotor.
VS
i also noticed that they make a cast verstion of the composite
J_E_E_P_X_J is offline   Reply With Quote
Old 11-14-2010, 08:35 PM   #20
volaredon
1997 XJ Cherokee
nevermind; I should have looked at what was written under the 2nd pic.....
volaredon is offline   Reply With Quote
Old 12-05-2010, 06:31 PM   #21
resident67
1989 XJ Cherokee
I must have replacement parts in my 89 because it had ball bearings... so if i want to use 90 and up hubs what else would i need????
resident67 is offline   Reply With Quote
Old 12-05-2010, 06:36 PM   #22
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Originally Posted by resident67 View Post
.... to use 90 and up hubs what else would i need????
1990 or newer outer knuckles, calipers, and rotors.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Glock Forum
