Quantcast Any difference in hubs...? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Any difference in hubs...?
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 01-12-2007, 05:26 PM   #1
Bryson
Is there any physical difference in Hubs between the cast and composite rotor'd XJ's? I'm trying to buy new hubs for my 99, but I'm not sure if there is a difference. I'm pretty sure I just have cast rotors, but I'm not exactly sure how to tell.
TIA
Bryson
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production - www.CortekSystems.com
Owner of Boostwerks.com
Website in development.
Bryson is offline   Reply With Quote
Old 01-12-2007, 06:59 PM   #2
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
  • Three different unit hub/bearing assemblies and matching disk brake rotor types were used over the years 1984-2001 on XJ D30 axles. (XJ, TJ, and ZJ, axles can interchange most parts, so the cast/composite info may apply to all.)
  • Two different steering knuckle types were used over the years 1984-2001 on XJ D30 axles.
Unit Hub/Bearing Assemblies:
1) 1984 through 1989 - Original AMC hubs ( Jeep Part Numbers 4723371, 5252725, 53000228, 53000234 )
AMC brake rotors, AMC calipers, AMC steering knuckles, and AMC roller bearing hubs.
The unit hub/bearing are the same part number for both sides of the vehicle.
2) 1990 through 1999.5 - Older type unit hubs ( Jeep Part Number 53007449 )
Uses Composite brake rotors and Chrysler calipers and Chrysler steering knuckles.
3) 1999.5 through 2001 - New type unit hubs ( TIMKEN Part # HA597449 - Jeep Part Number 5016458 )
Uses Cast brake rotors and Chrysler calipers and Chrysler steering knuckles.
Steering Knuckles:
1) 1984 to 1989 - AMC Steering Knuckles. Left and right side steering knuckles have different part numbers and only accept AMC calipers.
2) 1990 to 2001 - Chrysler Steering Knuckles. Left and right side steering knuckles have different part numbers.
Any AMC or Chrysler steering knuckle will fit on any D30. Remember, unit hubs type, and brake caliper type, must match the steering knuckle type, Chrysler vs. AMC.
Brake Calipers:
1) 1984 to 1989 - AMC Brake Calipers. Left and right sides calipers have different part numbers and only fit on AMC steering knuckles.
2) 1990 to 2001 - Chrysler Brake Calipers Left and right sides calipers have different part numbers.
AMC and Chrysler calipers do not interchange, they must be mounted on the corresponding AMC or Chrysler steering knuckle.
Brake Rotors:
1) 1984 - 1989 - AMC Brake Rotors
2) 1984 - 1999.5 - Composite Brake Rotors
3) 1999.5 - 2001 - Cast Brake Rotors
Additional Info:
- XJ D30 unit/bearing hubs, disk brake rotors, brake calipers, and axle shafts are interchangeable for years 1990-2001, and HP vs. LP. You just need to have the rotor type, match the hub type, cast vs. composite. Or, just swap the hubs and rotors as a matched set. The calipers are exactly the same, cast vs. composite or HP vs. LP. The only D30 parts that will not interchange, HP vs. LP, are the ring and pinion gears.
- 2000 and 2001 XJ D30's are Low Pinion housings, just like the TJ Wranglers.
- Most XJ, TJ, and ZJ D-30 axle parts interchange.
- Cast vs. Composite rotors Identification and Measurement -
** You need to match the disk brake rotor type and measurements to the unit bearing/hub type and measurements currently on your XJ. **
Previous owners or a repair shop may have installed different type replacement parts. It is possible to have one old type and one new type unit hub.
If your hubs and rotors are not matched, there will be interference between the two parts, the tire/wheel assembly will be bound up and not move freely, and the Jeep will not move.
Lay your old rotor on your bench and measure from the bench to the top of the rotor. Be aware that your rotors may have been replaced previously and may have a different physical appearance than described and pictured below. The physical measurements will be the same as noted.
Factory original Composite Rotors should have a rounded off corner at the wheel mounting surface and look like two pieces joined together. Composite rotors have a thin sheet metal like appearance at the holes where the lug nut studs come through and measure about 1/8 "(.125) thick in this area. Blank rotor castings can be machined to composite rotor dimensions, which is why you have to measure the parts you have and are purchasing. Composite rotors have an overall height of 3 3/16".
Cast rotors have a 90 degree angle edge at the wheel mounting surface and look like they are one solid piece of metal. Cast rotors are thicker at the lug nut stud holes and measure between 1/4" (.250) to 5/16 (.320) in this area. Cast rotors have an overall height of 3 1/16".
*** Parts store replacement rotors may have a different physical appearance than the example pictures or the rotors on your Jeep, but they must have similar measurements to the rotors currently on your D30 front axle.
Some cast rotors are machined to composite rotors measurements. Therefore, you must measure your current rotors and compare the measurements to the replacement rotors at the parts store before purchasing. ***
If, after measuring your current rotors, you are still unsure of which type of rotor/bearing you have or if you suspect that a previous owner or a repair shop may have installed replacement parts, compare the Unit Hub Bearings to the pictures below.
Hub Type Identification -
- 1999.5 to 2001 unit bearing/hub on the left of the picture uses the CAST ROTOR. The 1999.5 - 2001 unit bearing/hubs have the taller ring around the 36MM shaft retaining nut. It is almost 3/4 inch tall and the hub has longer lug nut studs than older hubs. See the axle shaft picture below.
- 1990 to 1999.5 unit bearing/hub on the right of the picture uses the COMPOSITE ROTOR. The 1990 - 1999.5 unit bearing/hubs have the ring around 36MM shaft retaining nut that is approximately 1/2 inch tall. See the axle shaft picture below.
Note the difference in the height of the ring around the 36MM axle nut and the different length of the lug nut studs.
If your hubs and rotors are not matched, there will be interference between the two parts and the rims. The rim will be bound up by the interference and will not turn freely, and the Jeep will not move.
If this information has been helpful, please click on the "thumbs up" icon on the bottom right side of this section.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 01-12-2007, 08:38 PM   #3
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Great info man, thanks.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 01-12-2007, 09:56 PM   #4
Bryson
Can you also judge by the look of the rotor? From the pic it seems like the composite rotor has a rounded edge at the lugs, where as the cast has a typical 90deg angle.
There are two pictures of rotors, the top picture is a composite rotor and the bottom picture is a cast rotor.
VS
Old 01-12-2007, 10:39 PM   #5
EricsXJ
The Post man
EricsXJ's Avatar
Originally Posted by CJ7-Tim
Composites rotors will have an overall height of 3 3/16". Composite rotors will have a thin sheetmetal like appearance at the lug nut holes where the studs come through and measure .1/4 (.250) thick in this area.
Cast rotors will have an overall height of 3 1/16". Cast rotors are thicker at the lug nut holes and measure 5/16 (.320) in this area.
Very good post, but where did you get the measurements of the mounting flange? Those differ from the info I have. I ran into this when I installed the Warn manual hubs that require cast rotors and not composite. Per Warn, the cast rotors have a .250" mounting flange. I remember that when I measured my cast rotors (2000 XJ) they measured .250"... And per Warn, the mounting flange of composite rotors measure .125".
Also just to add to your descriptions of cast and composite rotors, the cast is one-piece and composite is two-piece. The difference can be seen in the photos above, making the top ones composite, bottom cast.
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 01-13-2007, 09:26 AM   #6
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Eric,
I was checking measurements on some spare parts and axles in my garage. They may be replacement parts which would explain the minor differences in the rotor thicknesses that I have vs the factory original rotors.
I have updated my original post and welcome any other corrections or additions.
PM me for details
Old 04-07-2008, 07:21 PM   #7
Mike94ZLT1
How messed up is it that I have 1 of each?
2009 Jeep Grand Cherokee Laredo 4.7, 4WD, Stock for now
2006 Ford E-150 4.6, RWD, "The Happy Bus"
2003 Jeep Grand Cherokee Laredo 4.0, 4WD, Stock for now
1999 Corvette FRC 383 LS6 stroker, build drivetrain, full suspension, not much left that's stock
1937 Ford 5 Window Coupe 327 SBC, M-22 4 speed, etc..
Mike94ZLT1 is offline   Reply With Quote
Old 04-07-2008, 07:54 PM   #8
sprintagogo
Hey, do I win. I was right!
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline   Reply With Quote
Old 04-07-2008, 08:26 PM   #9
Bryson
Looking back on this thread reminds me. If I would have known what I do now I would have gone with the 84-89 style hubs for the roller bearings, and matched em with the rotors. Oh well.
Old 04-07-2008, 08:29 PM   #10
Mike94ZLT1
Can I do that? Put 84-89 hubs and rotors on a 99?
Old 04-07-2008, 08:33 PM   #11
Bryson
I honestly havn't seen this done yet, but I've heard from a couple other members that it works without problem. The hub just a slightly different offset which is why it requires the matching rotor for the caliper to be in the right place.
Old 04-07-2008, 08:43 PM   #12
_Kyle_
Hmmmm....
_Kyle_'s Avatar
I remember me and smrtjustin sweating out his hub replacement (and u-joints) because he has aftermarket rotors and we really couldn't tell the difference. Lucky he ordered the right ones and we were all set. BTW, Rockauto has really great prices on Timken hubs - less than half the price of the dealer OEM ones.
-Kyle
1996 Grand Cherokee
RIP Troy (bigbluezj94)
1996 ZJ FOR SALE
_Kyle_ is offline   Reply With Quote
Old 04-07-2008, 10:21 PM   #13
Mike94ZLT1
Eh, nevermind... 84-89 hubs are more expensive, but the rotors are a little cheaper.
Old 08-06-2008, 10:11 PM   #14
jebmccall
1997 XJ Cherokee
how much stronger are the roller bearing hubs, is it worth it to swap them out? i seem to go through hubs every 2 0r 3 months on my 99. thank god for the warranty
jebmccall is offline   Reply With Quote
Old 08-06-2008, 10:39 PM   #15
wil badger
Stop buying junk unit bearings...Also what size tire and back spacing do you run ? It will make a huge difference in the life of the unit.
One Built XJ
wil badger is offline   Reply With Quote
Glock Forum
