Any difference between 97 4.0l block and older H.O. block? - JeepForum.com
post #1 of 5 Old 01-18-2010, 12:43 PM Thread Starter
TheZaZ
I have a 97 cherokee and the block is cracked up front by the water pump. So ive started pulling it.
I got another high output 4.0l sitting in my garage and I just wanted to know if there are any differences between the blocks? The older block I have is a '90 I believe but it is a high output motor.
I am going to do a complete rebuild/stroker setup. I just needed to know if there are differences in those blocks?
I know they made changes for the 97 motor but I thought it was just the head/cam/exhaust that got the changes.
any help would be great!
TheZaZ is offline
post #2 of 5 Old 01-18-2010, 02:20 PM
jebmccall
1997 XJ Cherokee
i believe the 96 and later blocks are stronger. but thats all i know
jebmccall is offline
post #3 of 5 Old 01-18-2010, 03:37 PM
cornbrizzle
1992 XJ Cherokee
If it's a 1990 block it's a renix block and if you a going to build a stroker that's the one you want, I think it has a stronger casting or more nickle or something like that and is considered a stronger/tougher compound I may be wrong and if so someone will correct me
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #4 of 5 Old 01-18-2010, 03:47 PM Thread Starter
TheZaZ
its definetly a high output motor. Has the intake/throttle body that the H.O. has. My uncle said he thought it was a 90 cherokee. Not sure since he was the one that pulled it out. Either way its a H.O.
Just dont want to start disassembling it until I know the differences.
TheZaZ is offline
post #5 of 5 Old 01-18-2010, 04:16 PM
Luke94XJ
1994 XJ Cherokee
they should be the same or pretty damn close from 91-01. Since you got the H.O. in your 90 you may have had a motor swap or gotten lucky and got an early H.O. However, I have also heard that the renix blocks were stronger, if you are interested, I'd look into that.
Luke94XJ is offline
What is the difference between 96-older and 97-up front tow hook brackets? Mark_ZZ3 XJ Cherokee Technical Forum 7 10-24-2009 08:41 PM
HO to non HO block AuburnXJ XJ Cherokee Technical Forum 9 06-26-2009 09:41 PM
new fuse block? am i a block head? 2nd alt? futurefd XJ Cherokee Technical Forum 3 02-12-2007 11:37 AM
new block weebz90 XJ Cherokee Technical Forum 3 08-28-2006 08:31 PM
Block help homelessduck XJ Cherokee Technical Forum 3 03-26-2006 03:06 PM
