Another weird starting problem - JeepForum.com
post #1 of 3 Old 07-17-2013, 11:08 PM Thread Starter
freebird_78
1997 XJ Cherokee
So the other day I accidentally left the glove box open which left the glove box light on, which drained my battery. Recharged the battery, but discovered a new weird issue.
When starting it up, it cranks fine. Has fuel pressure, has new ignition, has clean TB. But you need to give it gas to start it and keep it running for the first few seconds. Runs fine after that. Seems like the injectors aren't firing at idle for a while, then after a few seconds, everything is back to normal. Only started doing this after the battery drained.
Thoughts?
Thanks.
freebird_78 is offline
post #2 of 3 Old 07-18-2013, 12:13 AM
Holder350
1995 XJ Cherokee
Sometimes normal after a battery has been unhooked or dead. The computer needs about 3 full warm up drives before it relearns its parameters.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 3 Old 07-18-2013, 08:27 AM
Dukenukemx
1997 XJ Cherokee
Yep perfectly normal. Sometimes I have to hold the gas with my foot for a good 5 minutes before the computer learns how to idle on it's own.
97 Jeep Cherokee Sport - Custom cone air, exhaust header, KYB, custom Stereo, 2.5 inch Rear lifted
98 Jeep Grand Cherokee - Custom cone air, exhaust header, KYB
Dukenukemx is offline
