#1 | |
Another starting issue
Ok, I have a '91 XJ. This morning I turned it on and pressed the unlock button from the passanger side, well in the process of doing that the radio and the dome lights went out. So I turn it off so I can change that fuse, well after putting the new fuse the Jeep just won't start. I got a ride to work with the hopes of letting it sit and it would turn on this afternoon after work, not the case it is still not wanting to start there is crank just no turn, any ideas on what I can do to fire it up? Someone has suggested a short somewhere but there is juice going through the whole Jeep, it turns just not firing
[COLOR="Green"]Colorado Jeep Club Member #45[/COLOR] [COLOR="White"]And shepherds we shall be for Thee, my Lord, for Thee. Power hath descended forth from Thy hand that our feet may swiftly carry out Thy command. So we shall flow a river forth to Thee, and teeming with souls shall it ever be. In Nomine Patris, et Fili, et Spiritius Sancti.[/COLOR] Last edited by DKBlaze; 02-21-2007 at 09:16 AM.. |
#2 |
Pockets Officially Empty
I'm going to say check all your fuses again. Double check that something to the ignition didn't go out. From what it sounds like, you have crank/turn, but no fire. I would check fuses first. It sounds like there's no spark, so maybe something with the ignition. Check the fuel as well. Maybe the fuel pump (fuse) went out?
2000 Jeep Wrangler Sport 4.0L 5sp 4" Pro Crap lift, 1.25" JKS BL, 1" Brown Dog MML, 35 Maxxis Bighorns, Lock-Right up front & Detroit out back, Super 35, Jeeperman front bumper, Warn XD9000i, Raingler nets, homemade discos, Poison Spyder cage.....In the middle of a re-birth! Yellow Jeep Club Member #66 Colorado Jeep Club Member #66 KUK9's 00 TJ Stretch Build |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
