another locker question - JeepForum.com
post #1 of 12 Old 02-13-2011, 02:28 PM Thread Starter
whiteys_red_XJ
im looking to get an aussie or power track no slip locker for my xj in the rear but a quick question i saw a video on how they work and it said when u turn the locker disengages but if ur wheeling and u start to turn does it release then too? please help my understand this alil more
96 xj 3.5 rustys lift, 33x10.50x15 BFG MT, t case skid plate, front tow hooks, open front and rear diff, NP-242 T-Case 1 in drop, AW4 transmission, dana 30HP, chyrsler 8.25 stock gears, K&N drop in air filter, flowmaster 40 series, poweraid throtle body spacer
whiteys_red_XJ is offline
post #2 of 12 Old 02-13-2011, 02:42 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
All locker function in a similar way. They are locked until you start to turn, then they unlock (disengage). Pavement or dirt it's all the same.
CJ7-Tim is offline
post #3 of 12 Old 02-13-2011, 02:48 PM
Toms87
1987 YJ Wrangler
"Lunchbox" style lockers (open/closed) like you are talking about are locked when torque is applied. If you've got a rear locker, for example, it is locked when you apply the throttle and unlocked when you let off. Going around a corner on the street while giving it gas will lock the rear locker and cause the tires to squeal or scrape. In the front, when in 2wd, there is no torque being applied and the locker remains unlocked. Around turns, you just hear a mild clicking noise.
Toms87 is offline
post #4 of 12 Old 02-13-2011, 07:11 PM Thread Starter
whiteys_red_XJ
Ok toms87 I understand it better now
post #5 of 12 Old 02-13-2011, 09:45 PM
djb383
I believe with most auto lockers, the outside axle is unlocked in a turn, gas on or not. If enough gas is applied in a turn, and the inside wheel looses traction, then the diff locks when the inside axle reaches the same rpm as the outside axle. The diff only unlocks (auto lockers) in a turn.....or at least that's the way the PowerTrax No-Slip performs.....and it doesn't make a clicking/ratcheting noise in a turn. Had 4 of 'em in various vehicles, almost as invisible as a limited slip in a DD.
djb383 is offline
post #6 of 12 Old 02-14-2011, 05:05 AM
blingII
The Powertrax locks (both wheels pull) whenEVER torque is applied. I have them in two XJ's.
blingII is offline
post #7 of 12 Old 02-14-2011, 06:22 AM
Toms87
1987 YJ Wrangler
I have front and rear Aussie lockers in 2 vehicles and when you give it gas in 4WD, they are locked, turning or not. In 2WD only the rear locks when you're on the throttle. That's why debates pop up sometimes about driving and steering in snow with a front auto locker.
Toms87 is offline
post #8 of 12 Old 02-14-2011, 07:05 AM
bdodge
1997 XJ Cherokee
97' Cherokee sport 2 DR / 4.0 Power Tech, 5 spd MAN, Command trac / Dana M30/181MM front axel, Corporate 8.25 rear axel / 6.5" Bastard lift, 31X10.5 Daytona futura's on Cragar 15X8 soft 8's, Logans Metals Front winch bumper, Flowmaster super 44, Magnoflow high flow cat
bdodge is offline
post #9 of 12 Old 02-14-2011, 11:06 AM
djb383
When going straight, or both wheels turning same speed, why why would a auto locker unlock, gas on or gas off?
djb383 is offline
post #10 of 12 Old 02-14-2011, 01:04 PM
Toms87
1987 YJ Wrangler
I am not familiar with Powertrax lockers but I can tell you that Aussies have springs inside that push the locker to the open position. With even just a small amount of torque, the springs are compressed and the locker shuts to the closed position. That's as simple as it gets.
If I go around a turn, on or off road, heavy on the throttle, the tires will squeal and scrape.
If I coast through a turn with no throttle, the locker pops to the open position, clicks a little, and locks once I get on the gas. The force from the axle shafts turning at different speeds overrides what little/no force is coming from the drivetrain.
I just read the FAQs on their (Aussie) website and they are helpful but somewhat misleading.
Edit: Just to clarify, I'm basing this information from a few years of daily driving a vehicle with front and rear aussie lockers, and having them front and rear in my Jeep.
Toms87 is offline
post #11 of 12 Old 02-14-2011, 04:23 PM
djb383
Wouldn't the springs be pushing the 2 locker halves outward to the "locked" position (teeth engaged in the pic), not the "open" position (teeth disengaged)?
When the springs are compressed, wouldn't one side (outside axle in a turn) of the locker "open" (teeth disengage to allow differentiation), in a turn?
If the locker/axle doesn't need to "differentiate", going straight gas off, why would it unlock?
PowerTrax No-Slip don't ratchet/click/make noise in a turn, maybe it doesn't dis-engage when u lift the pedal......why would it need too, when going straight?
djb383 is offline
post #12 of 12 Old 02-14-2011, 09:42 PM
Toms87
1987 YJ Wrangler
Maybe I got it backwards on the spring operation (It has been over a year since the Jeep installation so I don't remember exactly what they look like) but the actual driving experience with the locker is exactly what happens for me. Like I said, I don't have any experience with the Powertrax No Slip. The locker also would not need to unlock when going straight, and maybe it doesn't. It probably works with 2 forces - power from the drivetrain vs power from the axleshafts wanting to move at different speeds. Whichever one generates more power/force is the one that wins (maybe?) I wish I could attach a video camera to my axles or something so I can show you.
Toms87 is offline
Yes, Another Locker Question 350zmarty XJ Cherokee Technical Forum 7 11-29-2010 10:42 AM
Locker question 350zmarty XJ Cherokee Technical Forum 6 01-02-2010 03:19 AM
Locker question dajeepman XJ Cherokee Technical Forum 8 10-07-2007 10:11 PM
locker question charlie_merrifi XJ Cherokee Technical Forum 3 01-25-2006 04:23 AM
locker question slayer2000 XJ Cherokee Technical Forum 7 06-26-2004 08:29 PM
