Another headlight question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Another headlight question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military DiscCurrie Currectlync Steering Upgrade Kits and Currie Anti-R
Unread 04-05-2010, 11:54 AM   #1
SpartaSpartan
1994 XJ Cherokee
Thanks for the help in advance...
I spent my lunch swapping out the headlight switch (headlights would flicker on and off), but now nothing works. When I put the push rod back in, I didn't feel like it caught, so it just slides in and out without the normal halfway point stop for the driving lights and then all the way for headlights.
Did I break it that easily, or do I need to monkey around with the rod to get it to grab? Should I be looking at something else?
SpartaSpartan is offline   Reply With Quote
Unread 04-05-2010, 01:30 PM   #2
SpartaSpartan
1994 XJ Cherokee
After looking at the old unit, I think the new one is broken. It won't grab on the plunger - cheap duralast replacement
Unread 04-05-2010, 02:41 PM   #3
SpartaSpartan
1994 XJ Cherokee
grrr.... pulled out the new one and now the plunger works fine. At least now I know how it goes in. I forgot to unplug the batter when I unplugged it, but I'll do that when I reinstall it. Did I screw up and possibly blow a fuse?
cherokee , headlight , switch
