Another edition of name that squeal! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Another edition of name that squeal!
Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!Rough Country Deals at JeepHut.com
Unread 10-19-2009, 03:27 PM   #1
BoogerT
Vehicle: '99 XJ sport, 140k miles, recent serpentine belt replacement, tensioned to 160 lbs. using krikit tool
Symptoms: Chirping that becomes faster and higher pitched with throttle. I'd describe it as bad bearing noise. From *looking* at it, appears to be the PS pump, but not 100%. What's throwing me is that there are no leaks or changes in noise as I rotate the steering wheel. Maybe idler pulley or water pump?
Before I spend tonight in the dark/rain, any tips for more accurate diagnosis?
BoogerT is offline   Reply With Quote
Unread 10-19-2009, 03:29 PM   #2
WashbardBand
1994 XJ Cherokee
my ps pump went and it was high pitched squeeling when my water pump **** the bed it sounded like a bearing
WashbardBand is offline   Reply With Quote
Unread 10-19-2009, 04:10 PM   #3
BoogerT
Maybe I'll replace both since they both have 140k on the clock, but that will only guarantee that the problem will be something else.
Unread 10-19-2009, 04:15 PM   #4
WashbardBand
1994 XJ Cherokee
yah i hate trying to find squeaks and squeals its annoying
Unread 10-19-2009, 05:06 PM   #5
Easy Gibson
If this helps, when my water pump went it was also doing the tell-tale coolant leak out the weep hole in the lower part of the pump.
Might want to check for that if you haven't.
Easy Gibson is offline   Reply With Quote
Unread 10-19-2009, 07:39 PM   #6
BoogerT
I'm pretty sure it's the PS pump and I figured I'd change it out tonight. 45 minutes or an hour perhaps. The Jeep had other ideas. Sometimes the Jeep wins.
The new pulley is too small for the PS pump shaft. I managed to seat it about 50%. Awesome. No amount of brute strength could get it seated. I quit when my hands started bruising and bleeding. No deal. Not sure where to go from here.
