Quantcast Another Cowl Air Intake write-up - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Another Cowl Air Intake write-up
Old 03-31-2009, 06:36 AM   #16
XscottJ
where did you get the rubber fitting that is around the hole where there flex hose is ? Summit or Depot?
Enough about this cowl filter... Lets get into the cage goodness ...Like he said !!!!
!!Just Empty Every Pocket!!
XscottJ is offline   Reply With Quote
Old 03-31-2009, 11:19 AM   #17
RussoGuitar
1989 XJ Cherokee
Yeah where'd you get that grommet? Really cleans it up, i need to do this for when my battery gets moved for my York.. nice work..
RussoGuitar is offline   Reply With Quote
Old 04-01-2009, 04:05 PM   #18
CalebsXJ
Why not just run flex tubing from the air box to the cowl? Then you don't have to cut into the top of the cowl... You would be able to leave the stock filter attached and not have to put one into the cowl?
Caleb
2000 Jeep XJ; Heated Leather; 5.5 w/ACOS; 32's BIGHORNS; RK 3 Link; RE Monotubes; Rock Sliders; Rustys TC Skid; Front & Rear Recovery; Cobra CB; Flo-Pro Exhaust; Airaid; Surco Rack; HD Steering Crossover; IRO Adjustable Track Bar; SOLID d30 Cover; Recessed Winch Bumper; Gorilla Silver Back Series Winch; Hella 500 Lights...
CalebsXJ is offline   Reply With Quote
Old 04-01-2009, 04:54 PM   #19
RussoGuitar
1989 XJ Cherokee
Caleb
Well he probably has a huge hole in the side of his stock airbox from his snorkel, plus eliminating the stock box opens up a ton of room under the hood, and lastly I think this method ultimately makes for a much cleaner setup.
Old 04-02-2009, 06:51 AM   #20
EricsXJ
The Post man
EricsXJ's Avatar
That rubber piece is a grommet that came with the ARB snorkel. I moved it here from the other large hole I cut back then. You could probably find something similar that would work, such as weatherstripping or body trim.
#1 - I would have to relocate my washer bottle yet again since I am using one from an older XJ that is located between the stock airbox and brake booster.
#2 - I would have to cut another hole in the stock airbox and seal another one up. Plus while I don't have anything in its place at the moment, it is nice to get rid of the stock airbox all together.
#3 - This way is much cooler, don't you think?
Eric
2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote
Old 04-02-2009, 09:25 AM   #21
GregB_00XJ
GregB_00XJ's Avatar
Werd....
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 07-13-2009, 10:00 AM   #22
ThaKingXJ
1997 XJ Cherokee
i hate to bring up an older post but i just did a search for cowl intakes and i fell in love with this... thank you ERIC!!! i am going to do this soon.
ThaKingXJ is offline   Reply With Quote
Old 07-22-2009, 05:24 PM   #23
Vassago
The Bike Guru
Vassago's Avatar
just a note to anyone else doing this, pepboys has the same flex hose for 19.99! just picked mine up today. save yourself a few bones
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f22/build-thread-year-later-01-xj-643365/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote
Old 08-26-2009, 04:49 PM   #24
2doorxj
i just want to say that this is an excellent write up, especially wit all the part numbers you included and what not. i just ordered all the materials and will do a the same intake setup as you.
thanks a lot!
2doorxj is offline   Reply With Quote
Old 10-04-2009, 10:30 PM   #25
nwfjarhead
Semper Fi
nwfjarhead's Avatar
the grommet for the firewall looks the same as one for a 3 inch light like used on the ear end on semi trucks. would it be ok to run flex hose all the way rather than the metal hose?
www.panhandleoffroadkrew.com
nwfjarhead is offline   Reply With Quote
Old 10-05-2009, 01:47 AM   #26
lilnapsak
1997 XJ Cherokee
i did pretty much the same thing in this thread. it gets a little hot, i personally wouldnt trust the tubing all the way because of the heat, the metal tube is actually cheaper than the flex tubing, not to metion the flex tubing isnt long enough to strech from the intake into the cowl. and the more flex tubing the better the chance for it to rip or tear.
[QUOTE=Back_In_Black;12988070]your not very good at trolling.[/QUOTE]
lilnapsak is offline   Reply With Quote
Old 10-05-2009, 02:49 AM   #27
chainerx
1997 XJ Cherokee
How do you think this setup would work in an area that sees a lot of snow in the winter?
1997 Jeep Cherokee
chainerx is offline   Reply With Quote
Old 10-05-2009, 06:42 AM   #28
nwfjarhead
Semper Fi
nwfjarhead's Avatar
I just figured it would be easier to install the valve cover breather in the flex but I see your point. how did yall install it on the metal pipe? weld a fitting?
Old 10-05-2009, 02:01 PM   #29
hpimichael02
what do you do when it rains?? do you stop driveing?? im in FL and when it decides to rain it pours, and i was just curious about that...
hpimichael02 is offline   Reply With Quote
Old 10-05-2009, 02:33 PM   #30
justanotherjpr
Cowl snorkels have been proven to work fine in the rain. In Eric's version, directly above the cowl is not exposed to the weather because the plastic does not have holes on the passenger side.
justanotherjpr is online now   Reply With Quote
Glock Forum
