Another brake issue - JeepForum.com
post #1 of 4 Old 06-25-2006, 09:34 PM Thread Starter
meiguy
Another brake issue
While applying brakes I get a constant knocking sound. The speed of the knocking is relative to how fast I'm slowing down. The sound use to be spuratic but happens all the time now. It's actually starting to get pretty loud and I can feel a vibration in the brake pedal after each knock as well. The jeep is new to me and not sure when the last time the brakes have been worked on. Seems to get worse the more weight in the jeep.
Also, sometimes on the first drive of the day the brakes seem to grab for a split second and then release. My driveway is sloped pretty good which is where it usually happens. Doesn't happen ever time, mostly on the first drive.
What do you guys think. Fixable or should I just turn up the radio.
meiguy is offline
post #2 of 4 Old 06-25-2006, 10:07 PM
XJ4oh
1997 XJ Cherokee
If you can feel it in the brake pedal I would lean towards a warped rotor.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #3 of 4 Old 06-25-2006, 10:16 PM
ChaoticBastard
Very common for the rear brakes on these vehicles to be (sticky) when you first drive off.And I agree on rotor warpage
2009 Mustang GT Premium
2012 JK Sport
MetalHead Jeep Club Member #33
Originally Posted by kairo
what's wrong with bombing poor people? It has all the awesomeness of bombing combined with removal of crime. It's like a win win situation.
Unwad your panties
ChaoticBastard is offline
post #4 of 4 Old 06-26-2006, 07:45 AM
conrasm
conrasm's Avatar
I'd pull the wheels and look for loose brake pads or even a cracked friction pad, check the rear shoes for broken self-adjusting cable, crack friction pad, broken retaining spring or nail and if the hardware looks in good shape, spray eveything off with some brake cleaner, either have the rotors resurfaced or replace them.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
Brake issue '94 GC 5.2 FALudwig XJ Cherokee Technical Forum 1 10-02-2009 06:18 PM
front brake issue 98CherokeeLTD XJ Cherokee Technical Forum 7 06-28-2009 12:25 PM
Weird Brake Issue! epix XJ Cherokee Technical Forum 1 10-27-2008 09:57 AM
Odd brake-light issue Luckyduck XJ Cherokee Technical Forum 1 07-04-2008 02:51 PM
Brake issue teqmod XJ Cherokee Technical Forum 0 04-23-2006 12:41 PM
