Another BB question.......yes I searched - JeepForum.com
post #1 of 3 Old 02-21-2005, 01:28 PM Thread Starter
mdoug445
mdoug445's Avatar
Alright, ive finally decided that all I need is a 2" BB so I can fit some bigger tires. I dont want to risk having to spend all the money on an SYE and driveshaft because I dont have the money. I was looking at the Rocky Road BB and I saw it has rear blocks along with shackles. The blocks are only 1/2 inch, but I thought that blocks and shackles were the hardest on leaf springs. Is this something to avoid, or what, because I cant seem to find another BB that has a 2" shackle in the rear. Also, does anyone know of a website where i can look at the tera-flex BB, i havent been able to find any.
Also, Im going to be getting replacement rear springs from quadratec. should i drive on them for a little while to break them in or would it be ok to install the new springs and bb at the same time?
Gone: 97 Cherokee Sport
mdoug445 is offline
post #2 of 3 Old 02-21-2005, 01:47 PM
JTruel
If you are buying replacement springs, just get taller spring packs and bypass the block or shackles... or go to the boneyard and buy another set of stock rear springs and do this:
http://www.rocklizardfabrications.co...dget_boost.htm
2000 XJ Classic
2005 LJ
JTruel is offline
post #3 of 3 Old 02-21-2005, 01:57 PM
Lagooz00XJ
or get the pro-comp springs from summit racing... They're supposed to give u like 2.5" i believe. Click Here
2000 XJ 4.0 aw4 np 242
Bastard 2.5" Lift
30" Kumho MT's
Belly Armor
RE H&T w/ front shaft
Lagooz00XJ is offline
Overdrive question (i searched) Jameslol XJ Cherokee Technical Forum 10 03-28-2009 08:57 PM
Airbag question and a distributor modification question! (i searched) Jameslol XJ Cherokee Technical Forum 2 05-11-2008 03:08 PM
Searched and Searched Cant find any info about Tomken Lifts,good or bad savage1978 XJ Cherokee Technical Forum 8 11-07-2005 03:23 PM
Tire Question ---- Searched FiveLiterEater XJ Cherokee Technical Forum 5 10-22-2004 09:48 PM
Fog Light Question - Already Searched JimmyTwoTimes XJ Cherokee Technical Forum 2 05-07-2004 08:44 AM
