Quantcast another 8.8 thread - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > another 8.8 thread
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 03-06-2005, 07:29 PM   #1
moonlight_dan
1999 MJ Comanche
another 8.8 thread
I just found a ford 8.8 at one of the local junkyards. It's off of a 96-99 explorer. Comes with disk breaks and 3.73 gears. The calipers and disks are gone. The best part is that they only want $80 My question is, while i'm pulling it is there anything else on the explore that i will need for the conversion. Maybe the e-brake cables or something. Also, what spine could it possible have. Thanks
Ben
99 Cheromanche - Frame and bed are the only stock parts
90 Cherokee DD
moonlight_dan is offline   Reply With Quote
Old 03-06-2005, 07:42 PM   #2
GI-John
Since the discs and calipers are gone, take the driveshaft. You'll have 2 flanges that you can use an adapter U-Joint and not have to buy a spicer one.
The brake parts are gonna eat up a bit of your budget...be prepared.
92 XJ 4.0/AW4/NP242. D30 Truetrac Ford 8.8/EZ 4.88's/33's
Empty Wallet
GI-John is offline   Reply With Quote
Old 03-06-2005, 07:47 PM   #3
anony91xj
Ben
8.8 is probably a 28-spline.
1997 VW Jetta - Daily Beater <---Totaled, seeking replacement DD
2004 GMC Envoy - Wife's Ride
anony91xj is offline   Reply With Quote
Old 03-06-2005, 07:49 PM   #4
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
I thought thats a 31 spline
Matt
97 XJ - Black Sport, 4.0L AW4, D30 and 8.25
6" Skyjacker/RE, 33x13.5 Swamper LTB
Cracked Frame, good for steering!!!
MY XJ PICS
MSHarnett is offline   Reply With Quote
Old 03-06-2005, 07:50 PM   #5
anony91xj
Could go either way. I think the 31-spline was mainly for the bigger pickup trucks.
Old 03-06-2005, 08:54 PM   #6
hitech_hick
'95 and newer exploders came standard with disc brakes and 31 spline axle shafts. I believe that the '95 and '96 models came with either 3.55 or 3.73 gears and the '97 and up had 4.10 available. Most came with abs and Trac Loc, Ford's version of posi. The 8.8's that came with 28 spline axle shafts were the Rangers equiped with the 4.0 liter and the 31 spline axle shafts for the Rangers weren't available except in the newer FX4 models. Hope that clears things up
hick
'94 B4000, D35 TTB, Ford 8.8, 35's - Trail Rig
'97 XJ D30, Ford 8.8, 35's - Trail Rig
'98 XJ Limited Stock - DD
hitech_hick is offline   Reply With Quote
Old 03-06-2005, 08:58 PM   #7
moonlight_dan
1999 MJ Comanche
Thanks for the info guys. Anything else?
90 Cherokee DD
Old 03-07-2005, 11:04 PM   #8
hitech_hick
I don't have anymore helpful information to add, but I do have a quesiton of my own, do you need a different proportioning valve when you do this swap? I only ask because I bought an 8.8 out of a '98 explorer today and I've got it in my head to install it this weekend. It's got 31 splines, 4.10 gears and limited slip so yeah, I'll have to regear the front at the same time. I'm pulling together my list of parts hoping that I'm not forgeting anything; I know that I need the spring perches, shock mounts, brake lines, e-brake cables, adapter u-joint (don't feel like changing out the yoke), an possibly wheel spacers (still running stock rims). Is there anything else that I'm forgetting? And on another note, if this is so popular of a swap, why isn't there a tech write-up linked to the tech sticky?
hick
Old 03-08-2005, 12:58 AM   #9
silverxj2001
yeah there should be a sticky there
here's a writeup
http://xjfanatic.com/ford88.php
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
[URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL]
silverxj2001 is offline   Reply With Quote
Old 03-08-2005, 01:27 AM   #10
BACKROAD
On the proportioning valve, I'd use one of the aftermarket adjustable units.....The e-brake cables are available as a kit from LOKAR...
1956 Willys Flatfender....SOA, Buick V8, Turbo 350, locked both ends, wheelbase lengthened from 80" to 86", 35" TSL's on 15X12 Wheels...
1989 MJ.........4.0 with auto...2" BB and Rubicon tire PKG.
& a shiny new 2005 RED Rubicon Unlimited...RE3.5 Superflex and 33X12.50-15 MTR's and 15X10's. And a sad 10-13 MPG.......
4 WHEELING CAN BE AN ART WHEN APPLIED PROPERLY AND CARNAGE IS NOT A NECESSITY.......
BACKROAD is offline   Reply With Quote
Old 03-08-2005, 01:28 AM   #11
BACKROAD
I've got the part # of the LOKAR e-brake calbe kit if anybody needs it. Currie supplies this same thing with their 9" rear axles with disc brakes....
Old 03-08-2005, 06:58 AM   #12
xjmatt
hick
For the proportioning valve, use your stock one and see how you like it. If you don't like it I believe people have swapped in stock prop valves from WJ/ZJ's since they came stock with rear discs.
But as mentioned if you want total control buy an adjustable one.
And another good 8.8 swap writeup: http://www.bc4x4.com/tech/2003/xj88/
Good luck!
95 XJ sport 4.0L geared 4.10
AX-15 with an NP231
JB SYE with a High Angle CV driveshaft
RE 4.5" lift 33x12.5x15 ProComp AT's on AR 767's
JKS QD's RE HD trac bar & frame mount
Disc's on all 4 corners, stopping fast is so nice
Rusty's Airtube with K&N and Hella 500's on an ARB Bull Bar
xjmatt is offline   Reply With Quote
Old 03-08-2005, 05:12 PM   #13
Blue XJ
1988 MJ Comanche
I wouldn't use the stock prop valve, I always heard you need one from something with rear discs cause its quite a bit different.
While your at the yard, grab the calipers from the front, or at least from another vehicle so you can use them as a core when you buy the ones you need for the 8.8. Might save you $60 if they charge $30 core like they do around here.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline   Reply With Quote
Old 03-08-2005, 07:01 PM   #14
hitech_hick
I bought the axle yesterday and picked it up today, I couldn't be happier. I ran my finger across the rotors and couldn't have caught my fingernail in a groove it I tried. The pads also look brand spankin new and yes, I got the calipers as well. Now I just need a yoke from a Ranger, brake lines and e-brake cables and I'm all set. One more quick question, Are there any issues running stock rims on an Explorer rear end, or am I going to need different back spacing(or wheel spacers)?
hick
Old 03-08-2005, 09:47 PM   #15
MSHarnett
Broke Bogger
MSHarnett's Avatar
1997 XJ Cherokee
I am currently using stock valve with my ZJ disc brakes, not sure how diffrent 8.8 brakes would be though.As for backspacing, with stock rims you may hav a problem. The 8.8 is I believe an inch narrower, therfor depending on the tire, may hit the leaf spring. When you ever buy new rims/spacers I suggest you get rears ."5 less BS, just remember you can't do a full rotation then. Or you could just get a .5" spacer and rims
Matt
MY XJ PICS
Glock Forum
