Angry Cherokee Wont Behave..start and die every 30 min! wont start then run 30 later! - JeepForum.com
post #1 of 11 Old 06-05-2009, 04:26 AM Thread Starter
bcameron1974
Pissed of Jeep!!! LoL 1995 4.0 automatic 4x4 160k miles
Thing will start run for while then die like 15-35 min later! Try to start and starter will just crank!
no fire..
so put new crankcase sensor..and same thing ..it has new fuel pump and filter also..
Been doin this for while and running out of options.
I bought a Ignition Coil yesterday. First thing put it in...fired up ran for half hour and died..Tried to start didnt work! Tinkered with for while put some starting fluid in it and act liked it wanted to start..Put more gas in nothing thought maybe the gauge was wrong..Could hear the fuel pump kick on also..hit it with hammer..
Weird thing is I figured the ignition coil was good the old one so hooked it back up and it fired up...its got me stumped..I know it will die again because its same situation...any ideas? I even tried changin the fuel pump relay by switching the relay with the ac cluth relay...
my build thread.
1990 YJ 4.2 nuttered-mc2150-team rush-4 inch RC-1.5''-Shackles-1 1/2''-15x10 American Racing Atlas Wheels-33x15x12.50 Goodyear A/T-Hella Offroad Winshield Lights-Black Met/Gold Paint -Custom Gold Decals
bcameron1974 is offline
post #2 of 11 Old 06-05-2009, 05:19 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I would test for spark immediately after it shuts off, if no spark I would suspect the camshaft position sensor.
xjfever is offline
post #3 of 11 Old 06-05-2009, 06:36 AM Thread Starter
bcameron1974
i heard that it controls the fuel injectors and not the spark..it seems like they switch back n forth with fuel and spark issues when hot...the one on the bellhousing has been changed and the ignition coil wasnt the problem either...im assuming its the distr sensor camshaft..aka pickup coil? what u all think..im actually fixing this for a freind ...i have a wrangler 4.2 his is 4.0cherokee..
i tried testing spark..i might not of had a good source but seemed liek it didnt spark..but later it would fire..then no fuel... its retarded...
my build thread.
post #4 of 11 Old 06-05-2009, 06:52 AM Thread Starter
bcameron1974
anothe wierd thing is sometimes..no clicky when turning key..or start..but still dont explain the dieing when warm... any help
been reading about a nss what this?
my build thread.
post #5 of 11 Old 06-05-2009, 10:54 AM Thread Starter
bcameron1974
gauges jump too rpms and mph when hittin gas they dance
my build thread.
post #6 of 11 Old 06-05-2009, 11:06 AM
justanotherjpr
Check the ground strap at the back of the head
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #7 of 11 Old 06-05-2009, 12:19 PM Thread Starter
bcameron1974
ok >>>update
I started jeep today and waited 45 min at idle for it too die. After it died and was warm I immediately tried swapping a few of the relays..and its wasnt the problem..So after that I installed the pickup coil and it started immediately...Im thinking or hoping thats it...it only took 5 minutes if that too hook up and had no time to cool down...what you all think? rather not drive it till I got someone that can follow..
I also did notice that i did play with that strap ground while it was running and after playing with it it jumped the rpms...it used to do that all the time..Ill prob clean that up!
So do you all think that the pick up was the problem? It also had a little bit of a miss at low rpms also b4..i
my build thread.
post #8 of 11 Old 06-05-2009, 12:34 PM
justanotherjpr
overheating igniton module?
post #9 of 11 Old 06-05-2009, 12:38 PM Thread Starter
bcameron1974
its not overheating...i was mentioning I think it might be fixed..havent had time to drive it...I bought the pickup coil..and at first started jeep and it ran for 45min then died as usual. After it died I immediately hooked up the new part..(pickup coil) its started as soon as i put part in. Before installing after it died it would have to cool down before restarting. After part it started first time after stalling! What u all think? I have this up for sale and dont wanna have anyone stranded if it does it agian! Sounds like it fixed it tho?
my build thread.
post #10 of 11 Old 06-05-2009, 12:43 PM
justanotherjpr
Overheating ignition module is different than overheating engine. The pickup coil should be changing the ignition timing based on RPM, but I suppose if it was bad it could short your motor out. Does it stall now?
post #11 of 11 Old 06-05-2009, 01:22 PM
mgramann
Have you checked for spark with a spare plug when it dies? I ask just in case it is fuel related, and the cooldown is enough to make things happy. A friends 91 had a bad fuel pressure regulator that behaved the same...
mgramann is offline
84 Cherokee wont start smitty81 XJ Cherokee Technical Forum 6 12-22-2008 02:07 PM
97 cherokee wont start..... Ozarktravis XJ Cherokee Technical Forum 0 11-04-2008 02:37 PM
96 cherokee wont start jrsechr XJ Cherokee Technical Forum 2 09-15-2008 08:38 PM
Wont start, wont crank, and blowers dont work. L20KEV XJ Cherokee Technical Forum 1 02-26-2008 09:16 AM
