amp installation - JeepForum.com
post #1 of 5 Old 08-24-2005, 10:05 PM Thread Starter
crazyxj01
amp installation
Hey guys,
Ive posted this in the radios and electrical forum, but i thought id do it here too cause i thought more people would have input on how to do it in a cherokee.
So i replaced all the speakers in my cherokee and now im planning on adding a 4 channel amp to give em a little more power. Ive never done anythign like this so im kinda clueless. I am using my stock head unit so am i correct in using a RCA line output converter? And whats the easiest way to connect the speakers to the amp without running all new wires to the speakers? Should i just extend the wires where they would plug into the head unit to the amp? Thanks for the help, Matt
crazyxj01 is offline
post #2 of 5 Old 08-24-2005, 10:42 PM
MSHarnett
Broke Bogger
MSHarnett's Avatar
I would suggest new wiring. Its really not that big of a pain, just takes some time. The amp is going to push more power, so the wires need to be capable of handling the extra load.
As far as the instal, well I'm not exactly sure how to do it on a stock head. Just about everyone gets aftermarket heads which already have RCAs, remote wire, ect.
Matt
MSHarnett is offline
post #3 of 5 Old 08-25-2005, 10:33 AM
TwoOne
I would definitely run new wiring for the speakers at least, that will save you a lot of trouble in the long run, especially because after you run the RCAs to the amp the wires for the speakers have to come off the amp, so the stock wiring isn't going to cover that (depending on where you mount the amp i guess), but like he said, more power so you need bigger wires to get the full effect, I would run 16 gauge from the local stereo shop, you can usually get it for $.20 a foot, and with my amp mounted under the rear seat 60 feet was more than enough to do everything I needed to all 4 speakers.
As far as the RCA converter goes it is pretty straight forward, you just tap into the speaker wires coming off of the stock unit and then run the RCAs to the amp.
Since you are using the stock head unit you aren't going to have a remote control, which is the wire that an aftermarket unit uses to tell the amp to turn on when the stereo turns on, with stock units the best thing you can do is tap a single wire into the switched power source (violet / orange stripe wire on my 88 XJ) and run it to the remote terminal on your amp, that way the amp isn't on full time, but turns on when you turn your Jeep on and is ready for when the stereo turns on.
Hope that helps
TwoOne is offline
post #4 of 5 Old 08-25-2005, 02:12 PM
el_chupo_
el_chupo_'s Avatar
First off, if you havent bought the amp yet, look for one with high level inputs.
http://www.crutchfield.com/S-9LSX8q2eq6R/cgi-bin/prodgroup.asp?g=120&avf=N&nvpair=AG%5FNumber%5Fof% 5FChannels|FF4%40Channel&nvpair=AG%5FGeneral%5FFea tures%7CYCSpeaker%5FLevel%5FInputs#see_all
that is a link to the crutchfield site. All the amps listed are 4 channel with speaker level inputs.
for the wiring, what I would do is pull the HU out of the dash, and pull all the stock speaker wires. At the speaker ends, unplug the wires, and tape on the new ones, that way when you pull, the new ones are already run. This will probably require some finness, and probably some time. Then, run the stock wires to the speaker level inputs on the amp, and viola, all ran. I would mount the amp under the driver or passenger seat, or under the back seat if you have enough wires. I hope this made sense, if not, ask.
2012 JK Unlimited Rubicon
1999 XJ - Sold
1988 XJ Cheif - Sold
el_chupo_ is offline
post #5 of 5 Old 08-25-2005, 03:42 PM
01JeepXJ
01JeepXJ's Avatar
yeah you are going to need to run new wire from the amp to the speakers.
I would also save up some more money and Get yourself a new deck.
It will sounds awsome when you are done, the XJ is a great car for sound.
Nice color !!!!
2001 Steel Blue Metallic XJ
(3.5", Rock Monitor Bumper ,Gila Monster Quarter Guards , Super Skink Sliders)
33"Trxus MT's-OME Shocks-PMW Door armor-H4 IPF Headlights-Labaron Hood Vents
**SOLD **
01JeepXJ is offline
4.10 installation Nelg7654 XJ Cherokee Technical Forum 1 04-29-2009 08:38 PM
PCM Installation??? wangtyme XJ Cherokee Technical Forum 1 09-08-2007 09:58 AM
LCA installation 4x4life XJ Cherokee Technical Forum 9 11-23-2005 03:05 PM
installation VTJeep11 XJ Cherokee Technical Forum 4 07-28-2004 05:17 PM
A-a-l Installation ??? rocknerd XJ Cherokee Technical Forum 6 06-18-2004 08:14 AM
