always blowing fuses in 99 xj please help - JeepForum.com
post #1 of 4 Old 06-01-2009, 10:27 PM Thread Starter
weegie22
I have a big problem the other night i got in my 99 xj and my dash lights and and my tail lights wouldnt turn on and the past few weeks i have been blowing fuses left and right any help would be appreciated, both ground cables seem to be fine.
1999 XJ RC 4.5, 2in. shackle and 1.5in. coil spacer, 33x12.50x15 TSL super swampers, steel winch bumper and rear receiver bumper, home brew snorkel, radio shack cb and pa,
weegie22 is offline
post #2 of 4 Old 06-02-2009, 08:50 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Multiple blown fuses usually indicates a failed part or a short circuit on a hot wire, not a ground.
What fuse keeps blowing ? Whatever is on that circuit is suspect and needs to be inspected or tested. The dash light not turning on gives you a good clue. A wire that has worn or cut insulation will also blow a fuse.
CJ7-Tim is offline
post #3 of 4 Old 06-02-2009, 09:01 AM
driverdave
1989 MJ Comanche
definitely a chaffed wire some where, tracing bad wires is some times a long boring process but at a repair shop it can be costely even with testing equipment.
Does it blow as soon as you put the fuse in? or while driving? If it blows right away look under the dash first, if it happens while driving check the wire run going towards the back end.
Do not just throw in a bigger fuse that can cause a fire, take the time to find the wire issue. Since it is wiring it could be in a number of spots to hard to say where to exactly look.
driverdave is offline
post #4 of 4 Old 06-02-2009, 10:30 AM
Kettles
I spent 6 hours poking around trying to figure out where I had a short. Use a multimeter checking for resistance, or with a connection feature if it has one. With the power off, connect multimeter to the body and then touch the other lead to different suspect hot (but not when hot) wires. If you have a connection, then that wire is grounded and that is probably your short.
Thats how i found the wire i had a short in. I never ended up finding the actual short, and ended up running my own new wire. Good luck.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
Blowing fuses curtsjeep XJ Cherokee Technical Forum 3 07-26-2009 08:49 PM
fuses keep blowing..need help mmaverick88 XJ Cherokee Technical Forum 3 06-25-2009 11:00 PM
Blowing Fuses Razor. XJ Cherokee Technical Forum 6 06-21-2006 11:55 AM
Blowing fuses.....why? PRYDE XJ Cherokee Technical Forum 3 07-14-2005 12:33 PM
blowing fuses Goonowsky XJ Cherokee Technical Forum 1 02-12-2005 04:55 PM
