Alternator... reman or new - JeepForum.com
post #1 of 11 Old 02-14-2011, 09:35 AM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
I'm pretty sure my loud whistle is my alternator, since it changes pitch when electrical accessories are turned on. I just helped my buddy put a reman'd alt from autozone in his Ford Ranger and it seemed pretty decent. Anyone have input on a good alternator to go with? I'm not looking for a 400 dollar mean green alternator, just a stock one.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #2 of 11 Old 02-14-2011, 09:41 AM
severous01
severous01's Avatar
i used duralast. and because i was always in the mud it had a lifetime warranty. i abused the mess outta that warranty
i'd suggest going with it. specially if you off-road any at all. one submersion or a ton of mud under the hood will wipe it out...believe me i did it a lot. of course i had water over my headlights several times. and the mud i was in was like brown water...so it got everywhere.
severous01 is offline
post #3 of 11 Old 02-14-2011, 09:44 AM
Hussler
1992 XJ Cherokee
If your in mud pits a lot go with a remaned one with a lifetime warentty.
Its drilled pretty hard on JF to not buy remand but if you abuse it with mud its going to die anyway
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #4 of 11 Old 02-14-2011, 10:03 AM
Mike1084
1979 CJ7
I use these guys for my alternators. http://alterstart.net/
Sometimes a whine or low whistle is normal depending on the demand the alternator has on it.
However if your belt is not tight the heat that builds up from the belt slipping goes directly to the bearings which will evaporate the grease, the noise you hear is eventual bearing/alternator failure.
Mike1084 is offline
post #5 of 11 Old 02-14-2011, 11:19 AM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
I put a new belt on and noticed the other one was pretty loose. It slipped sometimes when first started during wet. Never squealed but my A/C compressor also never worked and the only way I knew it was slipping was the alternator didn't charge for a couple seconds. I don't do mud very much, but I'm thinking the lifetime warranty is a good idea. The cheaper new alternators only have a 2 year warranty. I'm thinking the bearings are done on mine since the whistle can be heard inside my house when the jeep is first started outside.
-Josh
Build Thread:
post #6 of 11 Old 02-14-2011, 11:47 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
I agree--remanufactured w/lifetime warranty.
Michael
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #7 of 11 Old 02-14-2011, 12:59 PM
egodfrey
egodfrey's Avatar
Yuo your just gunna ruin it anyway, or just to be cool get a mean green alt
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #8 of 11 Old 02-14-2011, 01:52 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
Ok I'll probably go with the Duralast w/ lifetime warranty.
-Josh
Build Thread:
post #9 of 11 Old 02-14-2011, 04:40 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
I'm not big on reman. parts in general, but I do consider them for alternators, because of the big price difference.
But here is another option to consider. Have it rebuilt locally. There are a lot of shops (some very small) that deal with these repairs.
We have a small one man shop in my town that rebuilds starters and alternators for a song. A GREAT option.
Snoop around to see if you can find a shop that offers this, and get a quote.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #10 of 11 Old 02-14-2011, 05:04 PM Thread Starter
jeepkid03
Winning
jeepkid03's Avatar
Thanks for the info. I remember there being a few of those shops in my area, but it seems many of them have closed down. I'll see what I can find. Also, any opinion on what could cause my whistle? Its definitely a belt driven accessory, and seems to be coming from the front of the engine. The pitch changes when I turn on lights which makes me think alternator. I'm not one to usually throw parts at something, but I've narrowed it down to the alt or the P/S pump and the noise seems closer to the alternator.
-Josh
Build Thread:
post #11 of 11 Old 02-14-2011, 05:07 PM
tjwalker
tjwalker's Avatar
Use a "mechanics stethoscope" on these components to determine which one is bad.
Like a doctors stethoscope, but has an attenuator to filter out other noise.
A great addition to the toolbox for under $10.
tjwalker is offline
New reman is knocking khurley XJ Cherokee Technical Forum 20 06-01-2009 11:24 AM
Head Cracked Need Reman. RHINORON713 XJ Cherokee Technical Forum 3 01-09-2009 10:07 PM
Need info on reman. 4.0L engine MathewsVA XJ Cherokee Technical Forum 4 09-16-2008 05:26 PM
A/C Compressor: New or Reman tangofox007 XJ Cherokee Technical Forum 5 10-10-2007 10:38 AM
t-case rebuild reman gleucht XJ Cherokee Technical Forum 2 08-16-2003 12:16 AM
