all four power windows wont work can any one help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > all four power windows wont work can any one help
Northridge4x4 - Memorial Day SaleSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!RCI FUEL CELL BRACKET - Perfect for the back of your Jeep
Unread 05-10-2011, 05:00 PM   #1
apalmer
ive already posted a couple times but i guess i didnt do it right. sorry i am new.
but i have a 1992 jeep Cherokee Laredo and in February my fuel pump went out, so i had to get a new one put in. and ever since then my power windows wont work. my power locks work but not any of the windows. ive been told id have a better chance at getting struck by lightening than to have all my motors go out in each door. which makes since. ive taken it to a couple places and they dont know what could be wrong. ive had my fuses checked and i also visually checked the wires in the crack of the door and they all look fine. i took the driver door apart to look at everything also and it all looks fine. im just lost as to what to check next.
apalmer is offline   Reply With Quote
Unread 05-10-2011, 05:37 PM   #2
AZ Jeff
You are going to need a wiring diagram for your year, and a VOM to trace where you loose the 12V feed from the fuse to the switch assy in the driver's door.
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is online now   Reply With Quote
Unread 05-11-2011, 08:48 AM   #3
Paradise XJ
1990 XJ Cherokee
At least 3 threads so far.
Welcome to the forum...
Here's how it works. You post once for the single problem, someone answers, you answer, someone else answers etc. etc. thereby keeping the thread going.
Please don't start a new thread everytime...and use the search tool...and as far as the problem goes I don't have power anything so I dunno
Thanks.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Originally Posted by 87Warrior
A large crack can also hurt performance.
Originally Posted by jmaxey27 View Post
Yeah, the pipe hangs just fine
Paradise XJ is offline   Reply With Quote
Unread 05-12-2011, 06:16 PM   #4
apalmer
well then i really didnt need any input from you then did i?
Unread 05-12-2011, 06:31 PM   #5
no5son1962
The problem is likely to be in the driver door area. Maybe a bad switch, a broke wire, or bad connection. I would focus in the driver door area and the wires in the door jam. They tend to break there. AZ Jeff post #2 has good advice. A wireing diagram would make it easier. Some jeeps have a window lockout button that tend to fail. I am not sure what years. If it is the lockout button the windows still work with the driver controls.
95 ZJ 4.0L 3 inch Lift
99 XJ 4.0L 4 inch Lift
no5son1962 is offline   Reply With Quote
Unread 05-13-2011, 02:00 PM   #6
apalmer
thanks :]
