All 00-01 4.0L XJ Headers Offered - JeepForum.com
post #1 of 22 Old 01-02-2008, 10:25 AM Thread Starter
dudeinajp
dudeinajp's Avatar
I've seen this question asked a few times when searching, so I thought I would make a thread that contains all headers offered for the 00-01 4.0L.
(If I have missed any, let me know and I'll update accordingly)
Rugged Ridge Torque Tube Header
Black
409 Stainless
Polished 304 Stainless
Doug Thorley Headers- Chrome
(NO PICTURE)
Banks Torque Tube Header
(NO ACTUAL PICTURE REPRESENTATION)
Clifford Performance
Disclaimer: According to the Clifford Performance website
Fittment: All 1987-2005 Jeeps 242 cid (4.0L).
Based on this statement, I will include the following headers. I do not know personally if they will fit for sure or not. Again, this is based on Clifford Performance's website. I am/will not be responsible for any issues you may have with the following headers. Thank you!
Borla Header
Pacesetter Header
Black Painted
ARMOR* Coat
JBA Cat4ward Header
Natural Stainless Steel
Stainless Steel/Silver Ceramic Coated
Stainless Steel/Titanium Ceramic Coated
dudeinajp is offline
post #2 of 22 Old 01-02-2008, 04:29 PM Thread Starter
dudeinajp
dudeinajp's Avatar
bump for the later crowd.
post #3 of 22 Old 01-02-2008, 04:37 PM
bmyohn
Youngin'
bmyohn's Avatar
how do these deal with the O2 sensors that we have up on the headers? i think we have like 4 or something
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #4 of 22 Old 01-02-2008, 04:57 PM Thread Starter
dudeinajp
dudeinajp's Avatar
The headers should just bolt up to the down pipe (except Pacesetter, slip fit).
Here is another thread I started regarding eliminating the two cats in the down pipe and O2 sensors.
http://www.jeepforum.com/forum/f11/rugged-ridge-header-00-01-4-0l-xj-502184/
post #5 of 22 Old 05-01-2008, 12:07 PM
XJ2000
XJ2000's Avatar
Old thread, I know, but I FINALLY found the answer to my problems..... I'm very excited!
Ok, back to the regularly scheduled program..... thanks!
: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline
post #6 of 22 Old 01-20-2009, 09:10 PM
xer0
is there any bios to what header to get? any one have a review of ones they installed?
xer0 is offline
post #7 of 22 Old 01-20-2009, 10:28 PM
RockRodHooligan
RockRodHooligan's Avatar
Of the ones listed, I'd go with Banks, Borla, or JBA, all three have a reputation for putting out quality stuff. That being said, I haven't heard much in the way of how the two, 3 pipe headers are working out, because the single 6 pipe manifolds are notorious for cracking.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #8 of 22 Old 01-21-2009, 08:05 AM
xer0
these headers keep the pre-cat in place, so in that case you dont need to get the eliminators. But what is the advantage to remove these cats? Is there a header that removes them? Ow else can you remove them if u get one of theses headers?
xer0 is offline
post #9 of 22 Old 01-21-2009, 10:14 AM
badron
The Clifford's couldn't possible retain the stock precats. Or they move the precats way down the line from the head. It would take the precats longer to get up to temp. If you get them? Warm her up well before getting your tail pipe sniffed and try not to do it on a cold day like were having now.
The manifold mounted O2s are also mounted in tube 2 and 6. Not in the collectors. This mounting point only samples one cylinder. Not giving a true sample of it's bank. Still this will work fine unless a injector goes bad or compression drops bad on 2 and/or 6.
I really like the tubes that go down and get away from the intake as fast as possible. Much less chance of heating up the intake then most can of worms headers offered. (IMO) Fewer bends for the gases to make also.
There is several down side to them but with the right setup some real HP could be added over 2500 RPM.(((IMO)))
badron is offline
post #10 of 22 Old 01-22-2009, 05:54 AM
xer0
SHoudl i replace the pre-cats when i buy a header? or can i remove them from my system?
xer0 is offline
post #11 of 22 Old 01-22-2009, 06:33 AM
RockRodHooligan
a buddy of mine has a 00 TJ that doesn't have the pre-cats on his, he bought it like that. I'd like to take a closer look at it some day.
96 XJ:
***** inches...
post #12 of 22 Old 01-27-2009, 01:49 PM
xer0
Could you try and get a pic of how it set up.
xer0 is offline
post #13 of 22 Old 06-11-2009, 02:02 PM
G_baller
i have a 2000 and dont know what header to get either.. i am hearing a noise that is almost the same my 99xj did with a cracked manifold, thought i fixed the noise but its back now... its a chatter/hiss that is very noticable above 1600-2000rpms. any replys would be greatly helpful
G_baller is offline
post #14 of 22 Old 06-11-2009, 03:39 PM
90si
I've had my borla , (which includes down pipe to the cat/ gasket for both type exhaust ports / stickers AND a hat) for 3 years now.
It's hooked to a Flowmaster exhaust and cat,with a 2000
intake manifold swap I've got great power throughout the
powerband and a good sound.
Btw I had mine jet coated for towing..it's all good
90si is offline
post #15 of 22 Old 04-21-2010, 02:50 PM
Gnl.Weirdness
awesome thread, up to the top.
Gnl.Weirdness is offline
AW4 offered in a 4 speed. 01ClassicXJ XJ/MJ Cherokee Non-Technical Forum 2 06-05-2009 04:49 PM
Largest Tire Offered From Factory... Grand Fan 4eva XJ Cherokee Technical Forum 6 06-02-2009 03:37 PM
which headers should i buy? jeep81 XJ Cherokee Technical Forum 1 12-27-2007 05:32 PM
Dana 44 axels offered? Chumpbusta XJ Cherokee Technical Forum 1 02-27-2002 09:22 PM
exhaust's are offered for the XJ XJin96style XJ Cherokee Technical Forum 12 01-24-2002 07:31 AM
