Alignment can't correct this? - Page 2 - JeepForum.com
post #16 of 21 Old 06-15-2012, 02:33 PM
rssuby2001
1987 MJ Comanche
I am a mechanic for 12 years, toe will wear the inside edge of tires, check all the joints, track rod bushings, and the bushings on the control arms, if they are worn your toe will change as you apply your brakea
rssuby2001 is offline
post #17 of 21 Old 06-15-2012, 03:29 PM
93gc40
Adjusting the caster will change the camber a little.
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #18 of 21 Old 06-17-2012, 07:33 AM
GreenliftedTJ97
Originally Posted by ltrail View Post
Caster doesn't wear tires. That inside only wear is bad camber which is why I said check bearings and ball joints. They actually do make adjusters for camber and caster for full size straight axle trucks. I have never seen them for a jeep.
Adjusting the control arms will do no good in correcting the camber.
Any decent shop will check the ball joints and tie rod ends before aligning. Alignment is useless woth worn front end parts.
Wow,wow & wow. Then what are the cam bolts for on the arms, why are the top ball joints staggered inward from the bottoms?
Green Jeep Club member # 456
New Jersey & you, broke together since 1787
GreenliftedTJ97 is offline
post #19 of 21 Old 06-17-2012, 08:35 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Really this could be fixed in your driveway with a tape measure and a pipe wrench.
I did a driveway alignment on my XJ after replacing the draglink and upgrading to a ZJ tie rod, and after I lifted my XJ.
EDIT: http://go.jeep-xj.info/HowtoAlignment.htm
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #20 of 21 Old 06-17-2012, 06:36 PM
GnarlyCharlie
1997 XJ Cherokee
This.
edit:
Do some Jeeps have cam bolts? Neither of my XJs have had cam bolts so therefore no caster adjustment is possible. I might just be unaware, but I didn't think any XJs had cam bolts.
GnarlyCharlie is offline
post #21 of 21 Old 06-18-2012, 11:11 AM
theshaolin
They definitely have a caster adjustment where the LCA bolts into the frame bracket.
1996 Cherokee Sport - 4x4 4.0L - Wheeling Project
1986 Mazda RX-7 Turbo - 400RWP project - 2000 Saturn SC1 - Turbo RWD project
1996 Suzuki Bandit 600 - Frame up restore project - Too Many Projects!!
1991 Chevrolet K1500 - 4x4 5.7L 5spd - For Sale (Cheap!)
theshaolin is offline
Is this correct..? horse1177 XJ Cherokee Technical Forum 14 06-12-2012 04:22 PM
atf+4 in np231 correct? jeepski89 XJ Cherokee Technical Forum 10 02-13-2011 06:34 AM
Which is correct? jwarfield XJ Cherokee Technical Forum 3 03-08-2008 11:25 AM
Can I get the correct MPH GDSQDCR MJ Comanche Technical Forum 5 06-12-2005 07:55 AM
Correct output JAS39C XJ Cherokee Technical Forum 1 06-22-2004 01:45 PM
